First post, by rodney007
Hi guys,
I am trying to get Nira drag racing to work,
I can mount the game fine and the ISO image using config on DOSbox,
I Install game, everything fine however when I run the games i am prompted with "insert CD" and cannot play.
ISO is mounted seems to be correctly mounted to D, as I can install it from that, and game install is mounted to C, which i run the main game .exe from.
I get the same problem when I use Launchbox with iso mount locations setup correctly.
However, when I install the game using Virtual VM box with an actual Windows XP install its fine, no CD prompt (however emulation is slow and laggy).
Its almost like the game install cant see the disc is actually mounted? terribly frustrating, any help appreciated.
Cheers!,
Rod
