First post, by wannab
I jus installed dosbox .63 to play some of my old games i dug up. everyting works fine with the games i play except for the sound,lots of popping and cracking when sounds are played an the popping continues for a few secs after the sound stops. its more of an annoyance than anything, but i was wondering if there may be some values i can tweek to maybe stop this. Also is there a way to change the window size of dosbox, without using dfend i dint care for that prog much
