First post, by Max15255
I have 2000 copies of an old DOS title called "Dino Park Tycoon", on CD. Most of the schools and students we work with are unable to run it now on WinXP. Is there a way to produce a program that will install the emulater, then ask for the program CD and when completed create a program icon and be able to run "Dino Park Tycoon" from the hard drive? It would also need to put the computer back to its' original configuration when the program is exited and run on both WinXp Home and Pro.
