First post, by Alt+G
This is in regards to the now-famous problem of the ALT/CTRL function keys occasionally stopping to function in POP2. For the past few days, I've been playing this with a friend under DOSBox 0.63, and it looks like we have discovered some specific instances that trigger this problem (this is after a lot of trial and error)...:
- Getting killed by one of those wall-guillotines (this does not ALWAYS trigger the problem, but the probability is very high)
- Activating a crusher-trap (this one does seem to always cause the problem).
- Using the keypad 8 key to defend yourself in a fight (weirdly enough, this is actually true, haha... for some reason, if you use the 7 or 9 keys, the problem doesn't happen. We have actually tested this beyond all doubt... though it could be some sort of local problem on this machine, who knows).
Hope these clues might help the developers to fix the problem in a future version... any other frustrated players are welcome to add their own findings in here. 😀
