Munt Mac OSX version discussion
Reply 62 of 72, by Qbix
Rank DOSBox Author
DOSBox Author
device numbers might change if you add or remove stuff and if you select an invalid value, then dosbox uses the default (0?) I think.
Ideally, Somebody (me?) should code a mixer /listmidi for coremidi, then things would be easier to figure out.
Water flows down the stream
Reply 64 of 72, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
yeah, tested and works with numbers and yes, that I was able to select it previously with the mt3emuport and mt32emuport1 must have been a testing mistake.
Gonna need to adapt that to Exult but with port name 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 66 of 72, by Dominus
DOSBox Moderator
http://xmidi.com/how-to-access-midi-devices-with-coremidi/ method 2 lists virtual devices like Mt32Emu as well (abd I got it to work in xcode). So coupled with device ID or num that you already get or check (?) in the coremidi driver it should be doable. I'll try a bit over the weekend but with my coding power I might not succeed 😉
Reply 67 of 72, by Dominus
DOSBox Moderator
Sergm (and Qbix), I noticed the settings get saved to ~/library/preferences/mt32emu.vogons.org.plist - I don't think that is appropiate. When you enter the plist url it should resolve to a real webaddress. In this case I think the plist should be named munt.sourceforge.net.plist.
*OR* Qbix can add that subdomain, mt32emu.vogons.orrg, and redirect either to munt.sf.net or to the mt32 forums.
It's by far not an important issue but I think it should be resolved at some point.
Reply 71 of 72, by Dominus
DOSBox Moderator
There is now some code that might make it into ScummVM to select the CoreMidi device https://github.com/digitall/scummvm/tree/core … DeviceSelection (discussion about it at http://sourceforge.net/p/scummvm/bugs/6579/).
I adapted this to Exult (already in SVN) and will most likely add this to Pentagram.
So these programs are more ready to use the munt-qt GUI 😉
Reply 72 of 72, by dr.zeissler
I picked up a G4-Mini with OSX Tiger. ScummVM 1.9 does work on it.
I'll check if this munt-osx-version will run on it.
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
