Munt mt-32 emulation gets stuck. (( Closed ))
Developer's Forum for discussion of bugs, code, and other developmental aspects of the Munt Project.
Re: Munt mt-32 emulation gets stuck.
Postby sergm » 2014-10-11 @ 16:18
Alternatively, you may simply use a DOSBox with MT-32 emu patch and don't bother with the app, if it is what you really need.
sergm
Postby Nic-93 » 2014-10-11 @ 16:47
sergm wrote:Exactly.
hmmm, the only way i honestly can get mt-32 emulation are in the app.
Nic-93
Postby sergm » 2014-10-11 @ 17:11
That's also weird... So, you're saying, even the MIDI driver doesn't work on your system?
sergm
Postby Nic-93 » 2014-10-11 @ 17:35
yep..im that much out of luck with getting mt-32 working,
Nic-93
Postby sergm » 2014-10-11 @ 17:43
Agree...
sergm
Postby Nic-93 » 2014-10-11 @ 17:44
Unless you can get a work around it.
Nic-93
Postby sergm » 2014-10-11 @ 17:58
I don't realize what could possibly happen that there would be no way to run a DOSBox binary patched with mt32emu :/
sergm
Postby Nic-93 » 2014-10-11 @ 18:17
Well, im one of those odd users.
Nic-93
Postby sergm » 2014-10-11 @ 18:32
Too bad :( I can't fix things not knowing what those are...
sergm
Postby Nic-93 » 2014-10-11 @ 18:38
like i said, its not moveing on from scanning for audio devices, and it stays there.
Nic-93
Postby sergm » 2014-10-11 @ 18:45
Like I said, it's irreproducible to me. You need to debug it.
sergm
Postby Nic-93 » 2014-10-11 @ 19:47
hm, well, i cant find the source at all.
Nic-93
Postby Nic-93 » 2014-10-11 @ 20:02
This thread can just be closed, ive removed it.
Nic-93
Previous
Return to MT-32 Development
Who is online
