SRPM for Fedora 26
Developer's Forum for discussion of bugs, code, and other developmental aspects of the Munt Project.
SRPM for Fedora 26
Postby Vascom » 2017-10-20 @ 07:55
Where I can find srpm or spec file for Fedora 26 rpm of munt?
Vascom
Re: SRPM for Fedora 26
Postby sergm » 2017-10-20 @ 09:21
This far, munt hasn't been ported to Fedora. Those RPMs which can be downloaded from the SourceForge page are generated using CMake, and that tool has actually weird idea of how RPMs should be generated :(
Anyway, by executing command
Code: Select all
cmake package
the binary RPMs are produced, so you can find the spec file in the package build tree and edit it a bit.
sergm
Postby Vascom » 2017-10-20 @ 09:25
I am try search spec file on github source of munt and not found it.
But if it is some sort of automatically generated spec then it not interesting.
Vascom
Postby sergm » 2017-10-20 @ 09:26
It is. Nothing human made I've found so far.
sergm
Return to MT-32 Development
Who is online
