First post, by a0divided
This isn't that much of an issue for most people, considering Munt is primarily used for gaming and most mt-32 supported games don't trigger this problem, but the "Engl Horn" patch (and maybe a few others, didn't check) sounds very distorted on lower notes played at max velocity. At around maybe 50% velocity the patch sounds fine. I tested this using both mt32 and cm32l roms and the problem persists. Even though I don't own a real device, I'm calling this a problem with Munt specifically since some older versions (1.0.0 - 1.2.0 iirc) don't exhibit this behavior/bug.
Also, are the Atmosphere and Soundtrack patches supposed to be non-responsive to pitch bend? Not considering this a bug, just asking.
