First post, by doshea
Hi all,
I would like to contribute a patch for the debugger, but the "Patches" forum only allows posting by moderators.
My patch provides the following functions:
1. The F3 key re-enters the previous command, just like in the COMMAND shell. No moving back and forth in the history though, sorry!
2. A new "MCBS" command which shows information about Memory Control Blocks, like running a "MEM /C" command but a bit lower level:
  47474293: MISC:MCB Seg  Size (bytes)  PSP Seg (notes)  Filename
47474293: MISC:Conventional memory:
47474293: MISC: 0158 16 0008 (DOS)
47474293: MISC: 015A 64 0000 (free)
47474293: MISC: (data addr 015B:0008 is 8 bytes past this MCB)
47474293: MISC: 015F 256 0040
47474293: MISC: 0170 192 017E
47474293: MISC: 017D 130688 017E INSTALL
47474293: MISC: 2166 272 017E INSTALL
47474293: MISC: 2178 576 017E INSTALL
47474293: MISC: 219D 752 017E INSTALL
47474293: MISC: 21CD 516880 0000 (free)
47474293: MISC:Upper memory:
47474293: MISC: 9FFF 196608 0008 (DOS) SC
47474293: MISC: D000 65520 0000 (free)
I used this new command to help me write a TSR-like wrapper which logs some data from within a game's memory. Since I had to manually work out which MCB the data was in, I also added the following feature to this command:
If your "Data Overview" is pointing to an address which lies within an MCB, the output will indicate the offset of the address within the MCB:
DEBUG: Set data overview to 015B:0008
22786822: MISC:MCB Seg Size (bytes) PSP Seg (notes) Filename
22786822: MISC:Conventional memory:
22786822: MISC: 0158 16 0008 (DOS)
22786822: MISC: 015A 64 0000 (free)
22786822: MISC: (data addr 015B:0008 is 8 bytes past this MCB)
How should I go about submitting this patch?
Thanks in advance,
David
Reply 2 of 9, by doshea
Thanks, moderator! Patch is attached to this post.
    debugger_f3_and_mcbs_cmd.patch.zip
    2.54 KiB
    87 downloads
    Patch: Debugger improvements: F3 key and "MCBS" command
Reply 3 of 9, by doshea
Should I have submitted this as a patch on SourceForge.net instead/as well, or is there something else I can do to get my patch reviewed and/or accepted?
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
It will be looked at when we are dealing with the debugger code.
It is not forgotten
Water flows down the stream
Reply 6 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
Some small things:
 Bit32u dataAddr = (dataSeg<<4) + dataOfs;
We have functions and typedefs for this kind of stuff.
and we have a function safe_strncpy which could be used in the f3 saving code.
Feel free to adept the patch to match that. Else I'll do that once I add some more stuff to debugger.
The patch looks fine otherwise.
I'm thinking of having a special debug command DOS which could MCBS as sub function. (and things like filetable, and fields of the DTA. (PSP etc))
Reply 7 of 9, by doshea
G'day,
Qbix wrote:
Some small things: […]
Some small things:
Oh yes, when I just looked I saw PhysMake(), however I'm pretty sure that when I'd looked previously I'd just seen the shift and add style code I used above. I much prefer the idea of the macro, though!
Sounds good!
I'm not sure when I'll get to update it, hopefully in the next few weeks. If and when I do, I'll attach an updated patch.
Thanks!
Sounds like a good idea, there could potentially be lots of those things! I'm afraid that right now I don't want to volunteer to do that, sorry 😀
Thanks,
David
