Parallel port passthrough (Windows only)
Here you can discuss the development of patches.
Re: Parallel port passthrough (Windows only)
Postby urbantaz » 2007-12-10 @ 19:37
Is there a specific version of dosbox this works for
urbantaz
Postby h-a-l-9000 » 2007-12-10 @ 19:46
What's the error message?
1+1=10
h-a-l-9000
DOSBox Author
Postby urbantaz » 2007-12-10 @ 20:27
it gives me a windows pop up error saying that the application needs to close. It only happens when trying to print. I am assuming it has something to do with the other app installed to give direct port access. It doesn't give any other errors except that app dosbox and module dosbox
urbantaz
Postby h-a-l-9000 » 2007-12-11 @ 13:52
Are you using Vista? I don't know if porttalk works there.
1+1=10
h-a-l-9000
DOSBox Author
Postby urbantaz » 2007-12-11 @ 17:57
no it is windows xp pro sp2
urbantaz
Postby h-a-l-9000 » 2007-12-11 @ 18:55
Are you using the build from my homepage?
What is written in the DOSBox status window?
1+1=10
h-a-l-9000
DOSBox Author
Postby urbantaz » 2007-12-11 @ 19:24
mmmmh now i am getting a different error without doing anything new
cannot open porttalk driver
failed to create hardware surface
urbantaz
Postby urbantaz » 2007-12-11 @ 19:48
not enough video memory
urbantaz
Postby urbantaz » 2007-12-12 @ 02:16
ok i am back to the original error maybe it has something to do with i need dos2usb to print as well
urbantaz
Postby h-a-l-9000 » 2007-12-12 @ 15:28
This patch can't be used with USB printing ports.
1+1=10
h-a-l-9000
DOSBox Author
Postby urbantaz » 2007-12-12 @ 18:49
i figured that but i believe dos2usb is supposed to make the pc think it has a lpt port but alsa as i type this i see that is a virtual port in windows and dosbox with your patch is looking for the direct access without windows
urbantaz
Postby h-a-l-9000 » 2007-12-12 @ 19:05
Maybe this one helps
viewtopic.php?t=13117
1+1=10
h-a-l-9000
DOSBox Author
Postby Johnatan » 2011-9-01 @ 09:49
h-a-l-9000 wrote:Could somebody please test if it compiles with MinGW?
wanted to renovate this question? No one?
Johnatan
Postby slpalm » 2011-10-29 @ 05:18
Does PortTalk work under XP x64? I'm trying to run DosBox Megabuild with PortTalk in order to have parallel port passthrough for a security dongle. However, the PortTalk driver won't load... Ugh...
slpalm
Postby h-a-l-9000 » 2011-10-29 @ 08:56
Porttalk is for win32 only.
1+1=10
h-a-l-9000
DOSBox Author
Postby slpalm » 2011-10-29 @ 14:36
Thanks h-a-l-9000. That certainly explains my problem. Is there any fundamental reason that PortTalk cannot be modified and/or compiled for x64?
slpalm
Postby h-a-l-9000 » 2011-10-29 @ 15:07
void Ke386SetIoAccessMap(int, IOPM *);
void Ke386QueryIoAccessMap(int, IOPM *);
void Ke386IoSetAccessProcess(PEPROCESS, int);
Not supported on 64-bit
1+1=10
h-a-l-9000
DOSBox Author
Postby slpalm » 2011-10-29 @ 15:13
Uggh... That's unfortunate. Thanks h-a-l-9000. Time for me to crawl off into a corner and sulk... :(
slpalm
Postby jlederma » 2011-12-05 @ 16:49
ok, I think I am missing somthing in my understanding here, I am trying to do a pass through to the printer that is set up on my xp machines lpt port. I have porttalk and ran it with the following "allowio dosbox.exe /lpt1"
in my dosbox config file have the following
in the printer section: "printer=true
dpi=360
width=85
height=110
printoutput=png
multipage=false
docpath=.
timeout=0"
and in the paralell section :"parallel1=realpt:ecpbase:378"
I can make it work with "parallel1=printer"
but the nature of the program is such that it really needs to be run full screen and exiting to deal with the printer dialogue is annoying. Any suggestions?
jlederma
Postby easyw3 » 2011-12-26 @ 18:13
does parallel port pass through work on win7 32bits?
thank you
Maurice
easyw3
PreviousNext
Return to DOSBox Patches
Who is online
