Super2xSaI, 2xSaI and SuperEagle
Here you can discuss the development of patches.
Postby Kronuz » 2006-5-16 @ 00:45
I've implemented the SuperEagle, Super2xSaI and 2xSaI scalers. Is anyone interested in those? I think Super2xSaI looks better than even Hq2x in some games.
If anyone's interested I'll build a patch.
Kronuz
"Time is of the essence"
User avatar
Kronuz
Re: Super2xSaI, 2xSaI and SuperEagle
Postby HunterZ » 2006-5-16 @ 15:27
If you've already done most of the work, I'm sure a lot of people would enjoy having the extra scalers to play with :) Personally I think those scalers make things look flat and cartoony, but for old DOS games that may work quite well.
You're perfect, yes it's true...but without me, you're only you.
User avatar
HunterZ
Postby Kronuz » 2006-5-16 @ 18:46
I'm attaching here the patch with the new scalers, including Hq2x and Hq3x. Also, in this patch, you can switch the current scaler in real time using ctrl+alt+F2 (at the moment, but accepting suggestions :)).
Please share your thoughts and experiences with this patch.
You do not have the required permissions to view the files attached to this post.
Kronuz
User avatar
Kronuz
Postby Qbix » 2006-6-12 @ 17:44
Hmm the eagle and sai scalers are smaller then the hq2x scaler :)
I presume the adding of the name is purely for debugging purposes ?
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby gulikoza » 2006-6-12 @ 18:26
name is written to the status window when scalers are changed with ctrl-alt-f2
User avatar
gulikoza
Postby Kronuz » 2006-6-13 @ 17:21
Well, yes, I just felt there was needed a way to know what scaler was currently selected and to actually have a way of knowing the real name of the scalers in a human readable form :)
Kronuz
User avatar
Kronuz
Postby starik » 2006-6-20 @ 18:07
first of all, thanks for making this patch/filters
second, is this patch included in dosbox 0.65?
and finally, Ctrl-Alt-F2 is not a good combo for linux. it is hardwired for switching virtual terminals.
starik
Postby Dominus » 2006-6-20 @ 18:12
no you have to patch it into the source and compile Dosbox yourself with it.
User avatar
Dominus
DOSBox Moderator
Postby Kronuz » 2006-6-22 @ 16:31
starik wrote:and finally, Ctrl-Alt-F2 is not a good combo for linux. it is hardwired for switching virtual terminals.
That's right, I didn't think of that... we'll have to think of some other key combination for that then...
Kronuz
User avatar
Kronuz
Postby Phil » 2006-6-23 @ 11:23
what about ctrl-alt and 1-8 like in scummvm? how can I patch the .diff file into the source and compile dosbox? i'd love to have the super2xsai scaler cause it looks so great in scummvm and I couldn't find any topics about compiling here :(
Help the newbie ;)
edit: found some topics bout compiling, but could anyone patch these scalers into the source code of gulikozas d3d patched version of dosbox, pleeeeze
User avatar
Phil
Postby gulikoza » 2006-6-23 @ 12:17
my build from 18.05.2006 already includes this patch...
User avatar
gulikoza
Postby Phil » 2006-6-23 @ 13:02
ok ya right i'm sorry :D it was just a problem with the into german patched dosbox.conf which didn't show me those scalers
but still the dosbox status windows says scaler:normal when I change the conf file to scaler=Super2xSaI?
and with ctrl - alt - F2 i can't change the scaler, everytime i press the buttons it says again "scaler:normal"
User avatar
Phil
Postby xJek » 2006-6-29 @ 03:05
how do u use it??? =S
xJek
Postby Phil » 2006-6-30 @ 07:42
how do i use what?????????
User avatar
Phil
Postby Phil » 2006-7-12 @ 17:31
no one who could help??? :sly:
User avatar
Phil
Postby ykhwong » 2006-7-12 @ 22:58
A message "scaler" in console window indicates which scaler is currently being used on screen. Some resolutions may not support scalers. Playing games with low resolution, hit Ctrl-Alt-F2.
ykhwong
Postby Qbix » 2006-8-05 @ 09:08
Added it to the cvs.
User avatar
Qbix
DOSBox Author
Postby gulikoza » 2006-8-08 @ 03:03
The new hq2x code (compared to old moe's patch) looks worse in some games. It looks almost the same as normal2x. I vaguely remember already debugging hq2x for tomb rider - it was some problem with palette changes and recalculating hq2x tables but the new code does this a bit differently afaik...
Screenshots taken with today's clean cvs (newhq2x and normal2x) and an older build with old hq2x code (25.1.2006).
User avatar
gulikoza
Return to DOSBox Patches
Who is online
Users browsing this forum: No registered users and 2 guests
