Timing patches
Here you can discuss the development of patches.
Re: Misc. timing patches
Postby Qbix » 2007-6-02 @ 06:26
wouldn't we risk with this patch that pc speaker games get their timer disabled ?
afterall some commands are send to both the speaker and the timer in this patch
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby h-a-l-9000 » 2007-6-02 @ 13:43
pcspeaker has its own implementation of the timer which is only controlled by the PCSPEAKER_SetCounter(p->cntr,p->mode) call in write_latch. The functionality of write_latch is not changed by the patch.
1+1=10
h-a-l-9000
DOSBox Author
Postby Qbix » 2007-6-05 @ 20:03
do you have some specs of that gate2 thing ? (specificly describing the link between the pcspeaker and it. I can find the gate 2 in the intel specs on the timer, but not it's linking to keyboard port)
The two patches related to the timer look correct. Will have to test that reload thingie with some demos although it is probably correct
User avatar
Qbix
DOSBox Author
Postby h-a-l-9000 » 2007-6-06 @ 18:54
Hmm, did you get my PM? Looks like it was lost?
1+1=10
h-a-l-9000
DOSBox Author
Postby Qbix » 2007-6-06 @ 19:14
I didn't get your pm.
Did you get mine ?
User avatar
Qbix
DOSBox Author
Postby h-a-l-9000 » 2007-6-06 @ 19:25
Yes. I'll write it again...
1+1=10
h-a-l-9000
DOSBox Author
Postby Qbix » 2007-6-06 @ 19:27
great. I'll edit this message if I got it.
edit: got it
User avatar
Qbix
DOSBox Author
Postby wd » 2007-6-06 @ 19:29
Before that have a look at the outbox/sent folder.
wd
DOSBox Author
Postby h-a-l-9000 » 2007-6-06 @ 19:57
It's not there, that's why I thought it got lost. (It said something about my session being invalid but apparently succeeded on the second try which it did not). I'm writing the message again now...
1+1=10
h-a-l-9000
DOSBox Author
Postby Qbix » 2007-6-08 @ 08:27
Commited overscan, reload, bcd and gate2(modified)
User avatar
Qbix
DOSBox Author
Re: Tming patches
Postby jcdutton » 2007-11-16 @ 17:20
Why not just use gettimeofday() instead of INT8 ticks?
ticks seem to no stay accurately in time over the whole day.
jcdutton
Re: Tming patches
Postby h-a-l-9000 » 2008-1-20 @ 15:25
An attempt at the midnight issue...
You do not have the required permissions to view the files attached to this post.
1+1=10
h-a-l-9000
DOSBox Author
Previous
Return to DOSBox Patches
Who is online
Users browsing this forum: HunterZ and 4 guests
