Glide patch
Reply 240 of 240, by kjliew
This fixed DOSBox glide pass-through issue when both glide pass-through and voodoo1 chip emulation are compiled in single build and used interchangeably. The problem was glide pass-through acquired window handle from SDL once and used the same handle all the time for grSstWinOpen(). The voodoo1 chip emulation broke this assumption because it hijacked and re-inited SDL upon every time it was in used. The fix also enabled DOSBox to use the patched OpenGlide/X11 without spawning new rendering window on Linux.
Patch for OpenGlide/X11 is available at:
QEMU 3Dfx Glide Pass-Through (WHPX/KVM works!!!)
After all, DOSBox and QEMU can share the same OpenGlide/X11 and OpenGlide/WinAPI builds on Linux and WIndows using native APIs, eliminating the SDL1 layer.
    glide_cpp.diff
    1.33 KiB
    16 downloads
    OpenGlide X11 windowed rendering
