Pc speaker beep ^G \a ... doent work in DOSbox?
Here you can discuss the development of patches.
Postby lc » 2008-7-07 @ 10:46
I have a C program using "putchar(\a)" to make a beep under dos.
but under Dos bos it doent work.
any ideas to solve it
I thank you in advance
lc
Re: Pc speaker beep ^G \a ... doent work in DOSbox?
Postby wd » 2008-7-07 @ 10:56
One topic is enough please.
BEL is not supported. Use some small program that deploys the pcspeaker
if you really have a need for that.
wd
DOSBox Author
Postby lc » 2008-7-07 @ 11:43
I thank you for you quick responce,
wath do you means about "deploys the pcspeaker"?
is it the same issue for putchar(\0x07);
best regards
Laurent
lc
Postby wd » 2008-7-07 @ 12:01
Yes, this is the same character.
Write some program that turns on the pcspeaker, waits for a short
while, then turns the pcspeaker off. Then you can just execute that
program instead of your putchar() thing.
wd
DOSBox Author
Postby h-a-l-9000 » 2008-7-07 @ 12:43
Or just make a patch for DOSBox :)
1+1=10
h-a-l-9000
DOSBox Author
Postby wd » 2008-7-07 @ 14:02
[note to self: kill hal by times] :pppt:
Can't think of any use for it at the moment though (the BEL thing, that it).
wd
DOSBox Author
Postby h-a-l-9000 » 2008-7-07 @ 15:41
I didn't say anywhere he should bother you to put it in CVS :kiss:
1+1=10
h-a-l-9000
DOSBox Author
Postby wd » 2008-7-07 @ 16:31
no but patches++
wd
DOSBox Author
Postby h-a-l-9000 » 2008-8-06 @ 15:57
Come and get me :P
You do not have the required permissions to view the files attached to this post.
1+1=10
h-a-l-9000
DOSBox Author
Postby wd » 2008-8-06 @ 17:45
Gotcha, but everytime i beat you you produce a *beep* how odd.
wd
DOSBox Author
Postby h-a-l-9000 » 2008-8-08 @ 14:39
I'm afraid you don't do enough damage...
(I like this one as it makes w95 shut down gracefully instead of lock or crash when told to restart)
1+1=10
h-a-l-9000
DOSBox Author
Postby Qbix » 2008-8-08 @ 15:04
there is an int 10 string printfunction as well. Saves a few calls ;)
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby h-a-l-9000 » 2008-8-08 @ 15:27
ah=13h?
I'd have to mess with guest memory though
1+1=10
h-a-l-9000
DOSBox Author
Postby Qbix » 2008-8-08 @ 15:39
ah yes. true. Stick with the loop then
User avatar
Qbix
DOSBox Author
Return to DOSBox Patches
Who is online
