My DosBox fork. OpenGL 3 GLSL shaders, FluidSynth (SDL2)
Here you can discuss the development of patches.
Re: My DosBox fork. OpenGL 3 GLSL shaders, FluidSynth (SDL2)
Postby Marty2dos » 2017-12-14 @ 10:56
Sorry friend, my Fork is for Windows.
Marty2dos
Postby Great Dragon » 2017-12-14 @ 19:51
@Marty2dos
Maybe it would be better if you start dedicated thread for your fork. To not confuse people.
@pintglass
You can use original Dugan's build if you use Linux.
User avatar
Great Dragon
Postby pintglass » 2017-12-14 @ 23:19
Great Dragon wrote:@Marty2dos
It is slightly confusing especially when Marty2dos's folk is windows only
@pintglass
I don't thing the original fork supports 3DFX
pintglass
Postby Marty2dos » 2017-12-19 @ 18:35
Yes, the Original Fork does'nt support 3DFX. I have no 'plan' from Linux or Mac. I'm a Windows Guy :)
I think you are right. I will do that with the next new version.
Marty2dos
Postby Great Dragon » 2017-12-27 @ 13:22
@Marty2dos
Here is the CRT-Simple OpenGL shader which was converted to D3D (CRT.D3D) by gulikoza.
https://github.com/SupSuper/OpenXcom/bl ... nGL.shader
So my statement about it was CRT-Geom was wrong.
But it doesn't work with your build. Despite it's written in OpenGL. But maybe it would be easier for you to check what requires to change to make it work.
User avatar
Great Dragon
Postby newoski » 2018-10-26 @ 01:04
Marty2dos wrote:Yes, the Original Fork does'nt support 3DFX. I have no 'plan' from Linux or Mac. I'm a Windows Guy :)
So I managed to compile this for Windows and I've got it working -- but I can't figure out how to enable the shaders for the life of me. Any help would be monumentally appreciated!
I've tried adding the following to my conf files, but it doesn't seem to do anything:
gl.shader=crt-lottes
output=opengl
scaler=none
I've also tried:
output=openglnb
Truly would make my day to get this going! I've tried so many builds with the goal of Lottes CRT shader... So close, but still so far
newoski
Postby Great Dragon » 2019-7-07 @ 16:08
@newoski
Here is part of my working config. I hope this will help you.
Code: Select all
fullscreen=true
vsync=false
fullresolution=0x0
windowresolution=1440x1080
windowborderless=false
output=openglnb
gl.shpath=.\DATA\SHADERS
gl.shader=crt-lottes_mod
texture.renderer=opengl
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=.\DATA\MAPPER-SDL2-SVN.map
sensitivity=100
Dosbox Splash Activate=true
Dosbox Splash Fadetime=100
Dosbox Splash Duration=600
Dosbox Shutdown Key=0
Works just fine with both OpenGL and OpenGLNB. Though I prefer to use "crt-lottes-mod" for myself with "OpenGLNB"
Here is an example of CRT-Lottes_mod shader configured to fit my taste
Code: Select all
#define hardScan -8.0
#define hardPix -3.0
#define warpX 0.000 //0.021, 0.007
#define warpY 0.000 //0.045, 0.021
#define maskDark 0.7
#define maskLight 1.8
#define scaleInLinearGamma 1
#define shadowMask 3
#define brightboost 1.0
#define hardBloomScan -1.8
#define hardBloomPix -1.5
#define bloomAmount 4.0/16.0
#define shape 2.0 //2.0
#define shadowmaskwight 3.0
User avatar
Great Dragon
Previous
Return to DOSBox Patches
Who is online
