SCALER Normal4-6x (DOSBOX)
Here you can discuss the development of patches.
Postby VileRancour » 2013-4-12 @ 16:31
Attached appears to be a fixed-up diff.
However, compiling with mingw results in screen corruption on CLS *if* normal6x is used (no issue with 4x, 5x). Wonder what's up with that.
(Edit by Dominus: on request the patches have been split off the topic viewtopic.php?f=32&t=35256&p=301919#p301919 and put into the patches forum)
You do not have the required permissions to view the files attached to this post.
User avatar
VileRancour
Re: normal4x, normal5x, one day ?
Postby VileRancour » 2013-11-26 @ 19:31
Added feature: "normal2x" and "normal3x" now work in double-width/double-height modes too.
Normally the internal scalers have zero effect on:
  • CGA/EGA 640x200
  • Composite CGA
  • CGA/pcjr/tandy 80-column text (incl. "160x100" games like Round 42)
  • EGA/VGA 40-column text
  • various tweaked VGA modes (320x400, 360x480/350, etc.)
The updated patch allows simple 2x/3x scaling for all of the above. You have to specify the 'forced' parameter (e.g. "scaler=normal2x forced"); this is a deliberate choice, mainly for consistency's sake.
(Moderators: could this thread be moved to the patches section?)
web  /   (NEW) blog   /   tube
User avatar
VileRancour
Return to DOSBox Patches
Who is online
