Reply 240 of 733, by Ant_222
Kisai wrote:
Ant_222 wrote:
You are correct. The exact PAR of 1.2 would be achieved by a 10x12 scale, but your display is not big enough for that, whereas a scale of 5x6 is considered too small by the algorithm, so it chose a compromise. The resulting aspect ratio is slightly off. Did you perceive this visually or by measuring? Should you prefer a 1600x1200 image with the exact aspect ratio?
I actually perceived this visually, which kinda did "something isn't correct here" itch. Like in the nearest-neighbor algorithm, the aspect ratio is correct, so the thing that you notice more is that the text-fonts are not the right shape.
So you perceived an error of
1 - (8/10) / (10/12) = 4%
I might need to add a setting specifying the relative importance of preserving the aspect ratio over using more of the screen area. This value is currently hard-coded in the patch (ASPECT_IMPORTANCE in pixelscale.cpp). If you increase it sufficiently, you will get a perfect 1600x1200 image, although too small.
So I suppose it would matter more if the source video is text or graphics. Text-mode things have a definitely wrong look to it, but are the least impacted, since we're talking about showing all the pixels, and is far crisper than a CRT could ever be. Remember that CRT's often analog controls and were never perfect, so I think the text-mode could get away with this.
I agree, for I have no discomfort in reading text magnified in a pixel-perfect manner either with or without aspect-ratio correction.
In graphics mode, it comes back to "is a circle a circle" which the test is typically Wing Commander. [...] Of the screenshots, […]
Of the screenshots, ScalePP seems warped just a little. But I think if the game was being played it wouldn't be noticed as much.
Scalepp, 104x110
Scalenp, 104x105
SDL2, texturenb 104x106
ykhwong d3d, 103x106
13x11 --[8x10]--> 104x110
which gives a 4% error as shown above. I can't comment on the other two cropped screenshots without knowing their full dimensions. On my system with surfacenp I have:
320 x 200 (1.2) --[4.2 x 5.0]--> 1344 x 1008 (1.2)
where 1344/1008 = 1.333
which is very close to the target 4/3 aspect ratio. Aspect-ratio error is best analysed using full screenshots.
Interestingly, it looks scalenp might be closer to an even shape.
Is scalenp a typo? surfacenb, surfacenp, and the hardware scaling modes of stock DOSBox should preserve the source PAR within tenths of a percent, which is an imperceptible difference.
Reply 241 of 733, by Kisai
Ant_222 wrote:
which gives a 4% error as shown above. I can't comment on the other two cropped screenshots without knowing their full dimension […]
Everything but surfacepp was 2560x1920, I then zoomed the desktop window screenshots in photoshop down to the pixel grid and cropped them around the radar circle in wing commander in the same way. The point was "does this look like a circle?"
And oops that was how I named the screenshot files since they would look identical.
Reply 242 of 733, by Ant_222
Then all the tiny differences are due to the local interpolation effects. They can hardly cause a perceptible difference in the shape of objects:
2560/1920 = 1.333 = 4/3
It is impossible to detect the exact boundaries between the source pixels if they are interpolated.
Yes, they all have identical aspect ratios, except for surfacepp.
Thanks for testing!
Reply 243 of 733, by marooned_on_mars
Is this patch working on linux?
I get this while I'm compiling:
sdlmain.cpp: In function ‘void ssPsEndUpdate()’:
sdlmain.cpp:641:50: error: cannot convert ‘unsigned int*’ to ‘Bitu* {aka long unsigned int*}’ for argument ‘2’ to ‘char ssGetOutPixels(Bit8u**, Bitu*)’
ssGetOutPixels( &pix_out.pixels, &pix_out.pitch );
sdlmain.cpp: At global scope:
sdlmain.cpp:663:37: error: ISO C++ forbids declaration of ‘ssSetSurfaceMode’ with no type [-fpermissive]
ssSetSurfaceMode( SURFACE_MODE mode )
sdlmain.cpp:682:8: error: ISO C++ forbids declaration of ‘ssFree’ with no type [-fpermissive]
ssFree()
Makefile:358: recipe for target 'sdlmain.o' failed
Used the Alpha 10 patch available in the first post of this thread with DOSBox SVN r4000
Reply 244 of 733, by Ant_222
marooned_on_mars wrote:
Is this patch working on linux?I get this while I'm compiling:
It should work on Linux, but I have only compiled in MinGW. I will analyse these erorrs and try to fix them. Thanks for the report.
Reply 246 of 733, by Ant_222
marooned_on_mars, please test the attached patch. I don't have a Linux environment set up, yet I think I have fixed the errors you indicated.
Reply 247 of 733, by marooned_on_mars
Seems that has fixed the errors on sdlmain.cpp, but now it complains on pixelscale.cpp instead:
pixelscale.cpp:245:34: error: ISO C++ forbids declaration of ‘init_bound_cols’ with no type [-fpermissive]
static init_bound_cols( info* si )
pixelscale.cpp:251:34: error: ISO C++ forbids declaration of ‘free_bound_cols’ with no type [-fpermissive]
static free_bound_cols( info* si )
pixelscale.cpp:304:77: error: ISO C++ forbids declaration of ‘handle_dwh_scale’ with no type [-fpermissive]
static handle_dwh_scale( char dw, char dh, ps_pixels *pix_in, ps_rect* rect )
pixelscale.cpp:411:72: error: ISO C++ forbids declaration of ‘get_pixel’ with no type [-fpermissive]
static inline get_pixel( ps_format_in fmt, uchar* whence, uchar* pixel )
pixelscale.cpp:437:74: error: ISO C++ forbids declaration of ‘put_pixel’ with no type [-fpermissive]
static inline put_pixel( ps_format_out fmt, uchar* whither, uchar* pixel )
pixelscale.cpp:497:78: error: ISO C++ forbids declaration of ‘inc_rect’ with no type [-fpermissive]
static inc_rect( ps_rect* rect, ps_size size, char l, char r, char t, char b )
Makefile:358: recipe for target 'pixelscale.o' failed
make[3]: *** [pixelscale.o] Error 1
The errors look similar.
When am I supposed to apply the patch? Before or after running autogen.sh?
Also, the patch doesn't seem to play nicely with munt's own diff file:
$ patch -p1 < dosbox-SVN-r3892-mt32-patch.diff
patching file src/Makefile.am
patching file src/dosbox.cpp
Hunk #1 succeeded at 492 (offset 1 line).
Hunk #2 succeeded at 508 (offset 1 line).
patching file src/gui/Makefile.am
Hunk #1 FAILED at 7.
1 out of 1 hunk FAILED -- saving rejects to file src/gui/Makefile.am.rej
patching file src/gui/midi.cpp
patching file src/gui/midi_mt32.cpp
patching file src/gui/midi_mt32.h
patching file src/mt32options.h
Anyone know what I must to to adjust munt's diff?
Reply 248 of 733, by Yesterplay80
Before you run "configure" even.
Do you know how diff files work? If not, I recommend reading this article first. It seems that the part of the Makefile.am the munt diff wants to change has already been altered by another patch before. Or the patch is for another version of the source file, maybe an older DOSBox version. Because of that, the patch routine can't find the pattern it is looking for and this results in the error you are getting. This might be something trivial like a line break, but might as well be something bigger. You have to compare the patched Makefile.am to the diff that's not working and see, wht exactly it tries to change and if you can actually find this pattern in the Makefile.am.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 250 of 733, by Yesterplay80
Ant_222 wrote:
marooned_on_mars, I will fix those errors. Does anyone know why they are not reported in MinGW with the same makefile?
Different compilers allow, forbid or tolerate different code, so I think it's just that.
Reply 251 of 733, by Ant_222
Different versions of gcc with the same settings? Very strange, especially considering that mine are blatant errors, I must admit...
Reply 252 of 733, by Yesterplay80
I don't know which compiler he's using. And I'm no pro at all, but I'm pretty sure different versions of the same compiler can do things different. You remember the graphic glitch in your DOSBox build? Same code, same compiler, different versions.
Reply 253 of 733, by marooned_on_mars
Obviously! I'm asking because munt's patch requires me to apply it after running autogen.sh
Thanks, I'll look into it.
It was intended for r3892, but it compiled on r4000 too. Sergm only releases those patches when major stuff are changed in DOSBox's code.
Thanks!
Seems at compile time, gcc v6.2.0 20161109 was used, according to the configure logs.
Reply 254 of 733, by Ant_222
marooned_on_mars, please check the attached corrected patch.
Reply 255 of 733, by Ant_222
That is more subtle. I have looked at the code that draws the welcome screen and did not understand a bit of it.
Reply 256 of 733, by marooned_on_mars
Okay, thanks for the fix Ant_222! This time it compiled properly. Though, I couldn't get it to stretch the image (or pixels) to the correct aspect ratio. Instead I get what I would normally get by using normal3x without aspect ratio correction. I'll read this thread in more detail to see what to change within DOSBox's configuration.
Also I fixed Munt's diff file, and I'll attach it. I would appreciate it if you could attach the file to the main post, so whoever might need it could see it.
Reply 257 of 733, by Ant_222
I can help you if you will specify your DOSBox settings and display resolution and give screenshots. Edit: Also pay heed to the Scaling: line in the DOXBox Status Window.
Reply 258 of 733, by marooned_on_mars
Settings:
fullscreen=true
fullresolution=desktop
output=surfacepp
machine=svga_s3
aspect=true
scaler=normal3x
My monitor's native resolution is 1366x768, which is the 16:9 analogue of 1024x768. I know, I know, I probably should get a bigger monitor, but money's tight right now. (gee, does that make me sound like a temporarily embarrassed millionaire... ugh)
I get this in STDOUT when I am in text mode:
Scaling: 640 x 400 (1.2) --[1.0 x 1.0]--> 640 x 400 (1.0)
And when in graphics mode/games:
Scaling: 320 x 200 (1.2) --[3.0 x 3.0]--> 960 x 600 (1.0)
So I'm guessing that the filter can't fit the corrected image? It should still work with 2x magnification.
Also you didn't say anything about my fixed munt diff. If you don't want to add it to the main post, then could you suggest me where I could post it?
Reply 259 of 733, by Ant_222
Interesring—I have never heard of this format.
Nope, I was not going to say that. My own main PC is some twelve years old and has Windows XP on it, and my other PC sports an old Viewsonic LCD with a resoltion of 1024x768.
I get this in STDOUT when I am in text mode: […]
You are correct. When my scaler is active, it overrides the scaler with none, so that won't help you. It is simply impossible to apply pixel-perfect aspect-ratio correction with your monitor.
I don't know what that munt diff is all about and how it is related to my patch. Do you suggest that I should include it into my patch and maintain it? What about the original author?
