I am trying to run a data aquisition program through DOSBox instead of regular old dos but I am having trouble getting the serial connection to work. I have actually contacted the DOSBox team and they have sent me on a couple of diferent routes, but they havent worked. The first thing i tired was a newer compiled version from
http://cvscompile.aep-emu.de/dosbox.htm. And i edited the config file for it like i was told to. That didn't work, so they sent me over here.
The system is rather old, because the data aq doesn't need much of a computer, P2 333, 256 ram, aopen MB, not sure on the vid card. The data aq system is connected to the computer through the com port by means of a fiber optic cable. I have tried many things, even to the point of trying different configurations for the COM setting in windows (Window 98 SE is what I am using) but have not beeen able to get anything to work. Any ideas?
