First post, by mathtom
hello,
first, sorry for my bad english (i'm french) !
i'v got two macs ppc under osx 10.4. I've installed dosbox 0.72 and f1gp runs on twice. i'd like to play in "link-mode".
With dapplegrey (gui for dosbox) i'v configurated :
first mac : serial1 : nullmodem on port 5000 (firewall deactivated); act as server and rxdelay=50
second mac : nullmodem client 192.168.0.1 (ip adress of first mac) on port 5000 (firewall desactivated) rxdelay=50
i obtain in the consoles :
first mac :
serial1 : nullmodem server waiting for connection on port 5000
second mac :
serial1 : connected to 1.0.168.192
first mac :
serial1 : A client (2.0.168.192) has connected
serial1 : Erros occured : framing 0, parity 0, overrun 2(IF0:0) break 0
what does it means ?
thanks for your help !
mathtom
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Please check that the DOSBox configuration files looks like this:
On Mac #1 (the server):
serial1=nullmodem port:5000 rxdelay:100
On Mac #2 (the client):
serial1=nullmodem server:192.168.0.1 port:5000 rxdelay:100
_________________
Reply 2 of 4, by IIGS_User
I do not have any clues how that works but I hope the frontend I've created does it well and right. 😉
if not, please check its DOSBox menu and choose "Show config file", to determine whether the frontend interpret it right.
On the way, interested to translate Dapplegrey into french (I know one person is too less to do it)?
Klimawandel.
Reply 3 of 4, by mathtom
hello,
thanks for your answers :
i tried with rxdelay:100 and then with rxdelay:5000 but i obtain the same type of error :
"overrun 1"
i tried without dapplegrey but it's the same thing.
Did anybody successed playing f1gp linked with dosbox ? (i've got great remembers when i did it with serial link on a pc 386...)
to IIGS_User :i've never done a software translation, i don't know how to do it, but if there is no programmation, why not trying ?
Reply 4 of 4, by IIGS_User
Hm, it's lot of text, no programmation required at your end, I think I should went to Grenier du Mac (where I'm also sitting as reader) to start a translation request, If I do something in that direction.
(better to remove your eMail from your posting now)
Klimawandel.
