First post, by Redeagle-GER
Hi guys
I'm trying to connect with a friend via dosbox over the internet.
As far is i read, dosbox tunnels the ipx, so it "should" be easy.
Both set ipx=true in the config
One startet the server, the other one wanted to join. but everey time, the connection fails / times out.
We tried vise versa
- ipxnet connect a.b.c.d (a.b.c.d of course being the correct ip-adress of the server-pc)
- ipxnet connect a.b.c.d 20000 port forwarded
- and tried to replace a.b.c.d with fixed.adress.org
Did we miss anything?
Or do we need a vpn-tunnel to get it worked although the "tunneld-ipx" seems to make this obsolete?
I am running vista-prof 64bit and he is running XP, both dosbox 0.74.
