First post, by DosWin
Hi.
Sorry, if topic abiut it is already on the forum.
I try to create connection with 2 copies of DOSBox with Win98SE. I planned to use it to play these by one copy on different PCs to Windows version of Dungeon Keeper, because not happy what DOS version works in 320x240 only - viewable part of map is small.
Connection with 2 copies of DOSBox is fine and dont have problems, but need do more steps to create a working IPX connection in Win98SE. My problem is I really dont understand whats need doing. I see some topics here throught google, but info is very uninform, because they all is about DOSBox+Real PC with Win98.
I will be very glad if anyone inform detailed, if it possible, intructions\guide about it, because working IPX on 2 copies on one PC will work on different PCs too.
Thanks.
Reply 1 of 5, by STX
Is this what you are trying to do? I'm confused.
│ Modern operating system │
│ │ DOSBox #1 │ │ DOSBox #2 │ │
│ │ │Win98SE│ │ │ │Win98SE│ │ │
│ │ │ │DK☺╞═╪══╪═IPX═╪══╪═╡DK☻│ │ │ │
That configuration will not work. Windows 98 SE will not run inside of DOSBox. You might have better luck with this:
http://keeper.lubie.org/html/dk_keeperfx_dwnld.php
Reply 3 of 5, by DosWin
I'm sorry, but you wrong. Post #9 from here - Glide 3Dfx and D3D emulation in DOSBox
Want to say - "wait Win9x support and 3Dfx\D3D in official\main line DOSBox"? I think while wait possible do something and play in "not official" DB Daum - run Win98SE, Windows games, run\do and fix 3Dfx and D3D emulation.
Otherwise much easier than waiting new version of DOSBox - go to the DOSBox Team and make possible Win9x and 3Dfx and D3D emulation in <official> DOSBox.
Simply exchange opinions pointless.
