IPX Dosbox + SoftXPand Duo Pro
For Multiplayer: Help and meet other players.
Postby arschul » 2015-2-17 @ 18:00
Hey guys,
I'm struggling here, need some help...
I've bought a license for SoftXPand Duo Pro, which gives me the ability to have two computers running on the same PC (add an extra monitor, keyboard and mouse and there you go). I set virtual IP and everything went smooth. Workstation 1 has its IP and so does Workstation 2. Downloaded DosBox on each machine and on number one I ran the command IPXNET STARTSERVER. On machine 2 I ran IPXNET CONNECT <ip>. When I run IPXNET STATUS it shows for machine 1 that the server is fine but no clients are connected. As for machine 2 it is the opposite. It shows it is connected but the server is not available.
Machine 1 status:
Server Status: Active
Client Status: Disconnected
Machine 2 status:
Server Status: Inactive
Client Status: Connected at <ip>
My configuration follows: (the virtual IP is disabled on SoftXPand only so it's easier to read the screenshot as it grays out when selected)
The image is not complete, on the right side I have set two IPs .11 and .12
Any thoughts?
arschul
Re: IPX Dosbox + SoftXPand Duo Pro
Postby Lo Wang » 2016-2-20 @ 23:24
I'm thinking maybe something related to the firewall. What does PING show for IPXNET connectivity?
Never used SoftXPand so I don't know what else could be getting in the way.
User avatar
Lo Wang
Return to DOSBox Multiplayer
Who is online
