IPX Help
For Multiplayer: Help and meet other players.
IPX Help
Postby DOSBOXER101 » 2015-12-12 @ 22:48
Hi
I have two chromebooks, both with ubuntu on it. When I try to play multiplayer games, the ipx won't work.
I did:
Computer 1:
Z:\> ipxnet startserver 2000
IPX Tunneling System utility for DosBox
IPX Tunneling Server started
Z:\>C:
Computer 2:
Z:\> ipxnet connect 123.456.7.89 2000
And it says it fails. What do I do?
Thanks
DOSBOXER101
DOSBOXER101
User avatar
DOSBOXER101
Re: IPX Help
Postby dagrimreefah » 2015-12-20 @ 19:17
What OS does comp 2 have on it? You might have to download some IPX shit for it.
Also, did you forward port 2000?
dagrimreefah
Re: IPX Help
Postby Sammy » 2015-12-20 @ 19:41
did you type the ip of computer1 when you connect with computer2?
Sammy
Re: IPX Help
Postby DOSBOXER101 » 2016-1-01 @ 00:38
1. The Second Computer has Chrome OS with XFCE4 on it, and the first Computer has Chrome OS and KDE. Could the OS be the problem?
2. I did the IP of Computer 1 on Computer 2.
DOSBOXER101
User avatar
DOSBOXER101
Re: IPX Help
Postby Sammy » 2016-1-01 @ 01:14
are both pc in the same LAN?
Sammy
Re: IPX Help
Postby dagrimreefah » 2016-1-05 @ 05:02
DOSBOXER101 wrote:1. The Second Computer has Chrome OS with XFCE4 on it, and the first Computer has Chrome OS and KDE. Could the OS be the problem?
The OS's should be fine. As the last person queried, are both computers on the same LAN? If they are, I'll also repeat my second question: Is port 2000 open? You can check by google searching "port open test".
dagrimreefah
Return to DOSBox Multiplayer
Who is online
Users browsing this forum: No registered users and 2 guests
