Duke Nukem 3D
For Multiplayer: Help and meet other players.
Duke Nukem 3D
Postby Zeca_galhao » 2016-4-12 @ 14:10
Can I play Duke Nukem multiplayer if I connect my 10 year old Sony VAIO to a 16 year old Toshiba?
Zeca_galhao
Re: Duke Nukem 3D
Postby brassicGamer » 2016-4-12 @ 14:39
It's arguably easier to do this through Windows (if both machines are running some kind of version) as you will benefit from simpler networking setup (optional WiFi etc.) and higher res textures if you want.
Setup both machines with one of the many Windows ports of Duke (e.g. http://www.eduke32.com/ but there are many others) and then get a hold of Duke3DMP from VatVit (http://duke3dmp.sourceforge.net/). I did this recently. It was little clunky to get going but worked in the end. Maybe I should write a guide on this - couldn't find one myself. Getting networking setup in Windows is technically a guide all on its own and is well documented.
User avatar
brassicGamer
Return to DOSBox Multiplayer
Who is online
