Trouble Hosting IPX
For Multiplayer: Help and meet other players.
Trouble Hosting IPX
Postby thefarstrider » 2017-4-22 @ 01:02
Hey Guys, hopefully someone on here can help me. I have had trouble hosting IPX games over the internet. I've had success using the IPX tunneling just on my home LAN, using the local IP address of my host computer as the ipxnet connect address, but when I try to host a game across the internet, I can't seem to get it working. For starters, I don't know what IP to use, as I believe my isp has moved over to IPv6. When I type ipconfig, I get:
Windows IP Configuration
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : santarosa.edu
Wireless LAN adapter Local Area Connection* 2:
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : attlocal.net
IPv6 Address. . . . . . . . . . . : 2602:306:cc2f:e9e0:f927:5362:5adc:39f8
Temporary IPv6 Address. . . . . . : 2602:306:cc2f:e9e0:3c88:459a:5a64:a731
Temporary IPv6 Address. . . . . . : 2602:306:cc2f:e9e0:4105:a43:58fc:c297
Link-local IPv6 Address . . . . . : fe80::f927:5362:5adc:39f8%5
IPv4 Address. . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : fe80::660f:28ff:febe:a3a1%5
192.168.1.254
Tunnel adapter Teredo Tunneling Pseudo-Interface:
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:90d7:14aa:3462:933d:161
Link-local IPv6 Address . . . . . : fe80::14aa:3462:933d:161%16
Tunnel adapter isatap.attlocal.net:
When I go to whatismyip.org, it tells me my IP is 108.194.254.158, which seems wrong, since I get the same result using a different computer but through my same wifi network. Makes me think my ips ran out of IPv4 addresses and now shares 108.194.254.158 amongst multiple users. Has anyone else had this problem? Any ideas?
thefarstrider
Re: Trouble Hosting IPX
Postby DosFreak » 2017-4-22 @ 05:30
Try http://test-ipv4.com/
I don't believe the version of SDL that DOSBox uses supports IPV6 although there are unofficial patches to SDL for it: https://bugzilla.libsdl.org/show_bug.cgi?id=2959
User avatar
DosFreak
Postby mrau » 2017-4-22 @ 09:21
sry but what you posted is hardly what you meant? i have no clue about ipv6 but if the ipv4 of that connection is a local one the other address is hardly your global ip; you might want to look at the gateway?
mrau
Postby thefarstrider » 2017-4-24 @ 03:10
DosFreak: Thanks for the links! I tried the IPv4 test and it came up with that same IP, 108.194.254.158, so unfortunately no leads there. As for the SDL, is that something I install that augments how DOSBox connects to other users? I'm almost entirely uneducated in computer networking.
mrau: I'm not sure what you mean. My local address is 192.168.1.100, which works fine when I connect to my other machine over my home network, but since it's a local address, that's not the one I've been trying over the internet. The only one I've tried over the internet is 108.194.254.158, which doesn't seem to work for reasons stated in the original post. Port forwarding through my firewall didn't help.
Does anyone know of a way of testing an outgoing connection? I mean, is there some server I can ipxnet connect to as a way of testing whether my ipx connection is working at all over the internet?
thefarstrider
Postby Jorpho » 2017-4-24 @ 04:18
thefarstrider wrote:DosFreak: Thanks for the links! I tried the IPv4 test and it came up with that same IP, 108.194.254.158, so unfortunately no leads there. As for the SDL, is that something I install that augments how DOSBox connects to other users? I'm almost entirely uneducated in computer networking.
SDL is an integral component of DOSBox and many other applications. The current reliance of DOSBox on SDL 1.x carries numerous limitations, but porting it to SDL 2.x is not a simple matter.
https://en.wikipedia.org/wiki/Simple_DirectMedia_Layer
User avatar
Jorpho
Postby AlphaPapa » 2017-5-04 @ 19:15
thefarstrider,
Hope you are still around. For the IPX tunneling/Emulation to work over the internet at least the host will need to port forward(to your internal 192.x.x.x) on your Router. The clients then will be able to use that external IPv4 address you found.
EDIT: I see port forwarded your "firewall" did you mean router? or just a software firewall like windows firewall?
AlphaPapa
Postby thefarstrider » 2017-5-06 @ 04:10
AlphaPapa wrote:thefarstrider,
Hi AphaPapa,
Thanks for the correction; you nailed it, that's exactly what I meant. I logged into my router and followed the instructions here:
http://www.noip.com/support/knowledgebase/port-forwarding-on-a-2wire-3801hgv-router/
Then I tried hosting from the machine I forwarded the ports to, but no luck. I also used a port scan website, and it told me those ports were still closed.
thefarstrider
Return to DOSBox Multiplayer
Who is online
