by Myg » 2018-3-22 @ 17:54
First of all, you need to install the IPX protocol on windows 7 before it can be used with kali, right?
I dont think Kali and dosbox will work together since they dont function the same way. You would need one friend to host a dosbox server and the rest to join it with their instances of dosbox for it to work. Kali uses its own system.
I am amazed that kali actually works after all these years.
I went to the website recently and there doesnt seem to be much signs of life.
