DOSBox IPX over Kali.net?
For Multiplayer: Help and meet other players.
Postby andreja6 » 2017-12-02 @ 03:17
Me and a few friends are trying to play Duke Nukem 3D over the internet. Me and another person use actual hardware and Kali to connect to each other. However, we have a few friends who use DOSBox. Kali can be used to emulate IPX on windows 7+, but we dont know how to make DOSBox use that instead. How would you do this?
andreja6
Re: DOSBox IPX over Kali.net?
Postby andreja6 » 2017-12-03 @ 01:23
Anybody?
andreja6
Postby Myg » 2018-3-22 @ 17:54
First of all, you need to install the IPX protocol on windows 7 before it can be used with kali, right?
I dont think Kali and dosbox will work together since they dont function the same way. You would need one friend to host a dosbox server and the rest to join it with their instances of dosbox for it to work. Kali uses its own system.
I am amazed that kali actually works after all these years.
I went to the website recently and there doesnt seem to be much signs of life.
Myg
Postby Danfun64 » 2018-10-03 @ 22:16
Technically it's dead. In order to use Kali nowadays, you'd need a cracked version from *redacted*. As for DOSBox, you'd need a version which supports NE2000 emulation.
am I allowed to link to the cracked Kali?
Danfun64
Return to DOSBox Multiplayer
Who is online
