First post, by vorob
I've connected two pc's via ipxnet in dosbox and everyting works fine, but Doom runs too fast: https://youtu.be/5jGA-g961xc
While singleplayer works at normal speed.
Tried to tune cycles, but it doesn't help much.
Reply 3 of 5, by neozeed
vorob wrote:
Problem solved. Doom 1.2 works fine, while Doom 1.1 rus fast on LAN... Sad thing, i wanted to play retro 😀
DooM 1.1 has absolutely terrible networking code.
That said I think it'd work with a locked cycle count... I've run it with Qemu although it's hard to say just how unplayable it was as it was just me.
Reply 4 of 5, by dr_st
Doom 1.1 is retro? Psshh, amateur. You shouldn't play anything newer than Alpha v0.3. 🤣
Reply 5 of 5, by chinny22
1.1 was pretty bad but it did allow 3 screen setup
Vanilla / Dos Doom in 3 screen mode. I finally did it!
1.2 broke this, but cant think of any other reason to use 1.1
