Stojke wrote:MHDD scanned the drive at 30MB/s and later tonight at 26MB/s.
Mhdd is not any way a benchmark program.
It count not transfer itself, but time between reading two nearest cluster, and since you controller is cached it can fake this seek time and report a smaller value.
Stojke wrote: The drive it self formated extremely fast
Yes, this is how cache controller works, all writes is cached, all verify is retry data momently, so format is performed very fast.
Stojke wrote:and windows 95 installed also extremely fast.
Yes, this is how cache controller works. Widows copy a bunch of small files, usually it means disk should read fat, write file, modify fat and again. This leads to lot work for disk heads and slowdown process greatly, so actual transfer rate is dropped to tens or hundred kb/s. And cache controller can hold all fat-changes and write only once in a few seconds, that mean it write mostly linear and transfer speed is limited only to bus speed.
Stojke wrote:So my only assumption is that it is running at 25MB ~ 30MB speeds using Tekram DC-300B.
No, this is can't be true.
Stojke wrote:I did some research and it seems that overclocking the ISA bus is possible
Not that fast. Usually you can try to run ISA on 10 or 12 mhz, but not every isa card can work on that speed. So 16mhz I assume as a theoretical limit, I think only specially designed card can work on that speed, bun none of massive developed cards.
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
