Reply 40 of 44, by mat919
Ydee wrote on 2021-09-17, 14:06:I'm afraid I can't help you with advice, my board is an older version of HOT 419 with the same chipset, but with a slightly modified configuration. But the configuration for the FSB is the same, and I noticed it's set to 50 MHz on your photo, which is why I wrote to you. The jumper settings table is correct, but the jumper numbers are jumbled, so it can lead to a mistake if a person is inattentive. For AM486DX4-120, the FSB should be set to 40 MHz (yellow indicated in my photo above).
I have seen this board before. I will check the HOT 419 manual. Maybe I'll learn something there.
Ydee wrote on 2021-09-17, 14:06:I cleared the CMOS by removing the connection on the jumper for the external battery (my board had a onboard NiCD battery), you can just take out CR2032. I think you can erase the CMOS by removing the link from the J1 jumper above the DIN keyboard connector - so I had it with me.
I did that. Did not help. I'll try all suggestions once I have new PSU. Thanks.
