Reply 20060 of 29615, by Kahenraz
I have an Intel i740 graphics card and it's pretty good. It's nothing special and it's not very fast but it worked well in my tests and would be a great choice for 2D and basic 3D.
I think these would have been a lot more useful if Intel had made them PCI. I don't think there are enough good PCI graphics cards for this era.
Reply 20061 of 29615, by RandomStranger
Kahenraz wrote on 2021-10-03, 19:10:
Yeah, I heard they are decent, but I want to test it. That's why as was collecting a lot of less common graphics cards from around '96-2000.
Also there were plenty of good PCI 3D accelerator graphics card in the later-mid-90s. Probably everything had PCI variants.
Reply 20062 of 29615, by Brawndo
Just working on cable routing and management in my newly acquired Windows ME era Compaq, make it as clean as possible in this old case. I installed a new 80 GB IDE hard drive which will be plenty for Windows 98. Haven't decided which video card I'm going to run in it yet, either a Radeon 9600 Pro or XT, or GeForce 2 GTS. This will just be a sort of all around, general gaming Win 98 PC.
Reply 20063 of 29615, by PC@LIVE
Restarted my old PC, it is a 386SX with a 33 MHz AMD cpu.
The MB is a GMB-386SAL with a soldered 386SX cpu, it currently has 2MB of ram, but if necessary I can easily upgrade it to 4MB by adding two more 1MB 30pin RAMs.
The coprocessor is missing, but for DOS use it is not a problem, the VGA is a 256KB Hualon ISA.
If I wanted, I could add an ISA sound card, but I don't know if it can be used, maybe it could be used for some video games, but most use the PC speaker.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
Reply 20064 of 29615, by Shreddoc
PC@LIVE wrote on 2021-10-03, 21:18:
Restarted my old PC, it is a 386SX with a 33 MHz AMD cpu. The MB is a GMB-386SAL with a soldered 386SX cpu, it currently has 2MB […]
Nice old machine, slow enough to cover the XT era (with Turbo off), AT era, and the beginnings of 32-bit.
Depending upon which games you intended to play, I would think first about a sound card, rather than RAM.
Because, and correct me if I'm wrong!, but it seems to me that Games benefiting from 4MB RAM + playable with a 386SX is a fairly short list, and Games playable with a 386SX + using a sound card is probably a much longer list.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 20065 of 29615, by aha2940
Intel486dx33 wrote on 2021-10-03, 11:31:
aha2940 wrote on 2021-10-02, 03:42:
Not PC retro related, but today I tried to play a CD on my discman sony D-E406CK: (pic is not of not my actual discman, but it i […]
Not PC retro related, but today I tried to play a CD on my discman sony D-E406CK: (pic is not of not my actual discman, but it is identical to mine)
However it would not work. It turned on the screen for a second, turn the disc about 2 degrees and power off again. So I disassembled it, did some tests and found that the lens was not moving. I had to disassemble the whole lens assembly, lube the gears and re-assemble the discman. To my relief, after this it worked again without issues.
🤣,…..Back in 1980’s I had one of those in my truck. It had a cassette deck so I had to use the cassette deck adapter for the Sony CD player.
Cool however I think you are mixing dates because those Discman units with the cassette thingie and the ESP2 feature did not come out until mid to late 90's. Anyway, I have the same cassette tape and power adapter. They were also useful for my minidisc, since it uses the same power connector and voltage as the discman (minidisc is an MZ-R37SP, still have it working fine).
Reply 20066 of 29615, by PD2JK
Swapped the cooler from a dead 6800 GT and installed it on a 6800 LE, because Nalu. And memory cooling for what it's worth.
Unlocked the extra pixel pipelines and vertex units as well, without artifacts.
Today was a good day.
Reply 20067 of 29615, by BitWrangler
Shreddoc wrote on 2021-10-03, 21:54:
Nice old machine, slow enough to cover the XT era (with Turbo off), AT era, and the beginnings of 32-bit. […]
Solution... buy an AWE32 with two 1MB SIMMs installed and swap those into motherboard. 🤣
Are we working on a super tight budget here though, I thought one could still find SBPro/Adlib compatible cards and 1MB SIMMs cheap enough, that it's not a $100 a pop either/or buy like it's 1993.
edit: though 33Mhz 386sx is probably capable of playing stuff that's 486sx25 recommended, even so called 486 games, they still didn't want ppl who had Oak VGA, no cache and a slug of a HDD complaining it was unplayable. As soon as you start seein DX2 on the box though tap out, even if it doesn't really use co-pro, it's shorthand for 50-66Mhz.
Reply 20068 of 29615, by PD2JK
BitWrangler wrote on 2021-10-04, 13:23:
That's very much a coincidence. I just got my hands on a CT3620 with I believe, 2x 1MB. 🤣
I'm afraid to damage the fragile plastic SIMM slots, so I will keep them in place...
Reply 20069 of 29615, by Sombrero
Most parts for my P3 build has arrived, so I started putting it together.
The 20pin motherboard atx power connector to 24pin PSU adapter.
There's always something you forget, it's like a law. No matter, I don't have the SD card adapter or the SATA to IDE adapter yet either, so I wouldn't been able to get to installing windows anyway.
Reply 20070 of 29615, by Sombrero
Sombrero wrote on 2021-10-04, 14:36:
Except this site here says I can plug a 24pin psu connector to 20pin motherboard as long it fits in there, is that right?
Reply 20071 of 29615, by sirotkaslo
Yes, some PCUs also have the atx connector as 20+4,.
Reply 20072 of 29615, by Sombrero
sirotkaslo wrote on 2021-10-04, 15:34:
Yeah, I was expecting the PSU to have 20+4 but didn't check. The manual says it's a 20+4 even though the actual connector is very much 24pin, there's no extra 4pin bit you can remove.
But now that I actually stopped doing a hundred things at the same time and tried to fit it in there, I noticed there's a coil on the right side and a jumper for enabling/disabling keyboard/mouse wake up fuction on the left side, so an adapter is needed. Oh well.
Reply 20073 of 29615, by PC@LIVE
Thanks for the suggestions, in fact a sound card could be useful, since I have some ISAs aside I plan to add it soon.
It is actually quite slow as PC, but when you think about it it might be because the turbo switch is not plugged in, and therefore probably runs at reduced frequency.
Today I connected the controller with CF-IDE adapter, the CF card I use is only 8MB (another 128MB is not detected), the PC starts up correctly, and I have tried some programs including hwinfo.
I have not yet decided whether to use a relatively small mechanical HD, or another larger CF, at least 128 or 256MB.
For the RAM I have a couple of 30 pin SIMMs to put in, but for the moment it is not necessary to have more RAM, I will put them on when I have the final configuration.
Reply 20074 of 29615, by macroexp
Received a pair of (used) SL25A Pentium Pro 200MHz 1MB processors to upgrade my Vectra. Hoping it can handle the increased TDP, maybe time to upgrade the cooling too.
Also took a crack at fixing my Toshiba 4015CDS which unfortunately is stone dead. Power supply is giving out correct voltage but zero signs of life. Took it apart and found no bulging or leaking caps or batteries, nor any scorched or suspect-looking components. Stumped…
Reply 20075 of 29615, by Sombrero
Tested a few gfx cards I've had lying around.
- XFX 7950 GT seems to have died, bumbgate claims another one I guess
- Asus EN7600 GT Silent on the other hand is still kicking, for the time being at least
- Gainward 9800 GTX+ is also working, but the fan doesn't sound happy. Need to macgyver some other fan on there
Reply 20076 of 29615, by 4dam
Brawndo wrote on 2021-10-03, 20:48:
Just working on cable routing and management in my newly acquired Windows ME era Compaq, make it as clean as possible in this ol […]
What Atlhon is there ?
I'm working on kind of simmilar project, and It's calling "Budget Tualatin Smasher". 😉
Instagram Retro
Reply 20077 of 29615, by PC@LIVE
Today I expanded the RAM to my 386SX, now with another 2MB they are at 4MB total, for the moment it is the maximum amount that can be installed, because I have filled all four SIM holders. Wanting and finding modules of 4MB each I could, by finding a couple, further expand the RAM reaching 10MB total (8 + 2), there are modules of this capacity for sale, but the prices are not so cheap, perhaps with some experience ( ?) you could do some mods to expand the capacity of the 1MB ones, I don't know if it is possible to combine two of them in order to obtain modules of 2MB each.
Reply 20078 of 29615, by creepingnet
Put the VersaDock backup for about 2 weeks, only to rip it down again because it died. SO the Versa-beasties are on the move now...got the V/50 with me today. Also ugpraded the XUB Firmware on the Tandy 1000A - such a speed improvement. I was still running the original 2008 Firmware.
Have not been messing with PC's too much though, most of my time has been spent playing Dragon Warrior IV on the NES as I finally got the cart. Just on the verge of winning (and having a god-tier savegame) again.
Future plans are
- fix the AT&T DS Docking STation (probably fuse or bad cap)
- Upgrade the Tandy 1000 (V20, 8087 - gamepad adapters)
~The Creeping Network~
Reply 20079 of 29615, by iraito
Kahenraz wrote on 2021-09-28, 19:23:
Even though I have nostalgia for my Pentium 4 experience, there isn't anything that this particular platform can do that a Pentium 3 or later AMD or Socket 775 system can't. Well, except for RDRAM but there is no advantage to using it over a slightly faster CPU with cheaper SDRAM or DDR. This is the era of PCI/AGP which isn't particularly special or exciting.
I agree on later CPUs but an average pentium 3 will struggle with a ton of games played at MAX after 2002 even with a decent Geforce 4, i never tried anything over a 933Hz for the P3 though.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
