First post, by Kahenraz
- l33t
I have a FIC VL-603 motherboard with an odd capacitor attached at the top right corner. When received it, one of the leads had broken off and was floating. The only place it seemed capable of reaching was the edge of a SMD resistor at R288.
The system powers on fine with or without the capacitor connected at this point. I wasn't certain that this was a factory modification or that I had reattached it to the correct location so I have disconnected it. But I have since found photos of other boards online with this capacitor present. Unfortunately, none are close enough to identify where my detached lead is supposed to connect.
Does anyone have any information about this board or own one that can photograph where this is supposed to attach?
