First post, by keenerb
With the system on I don't get any frequency readings across the two legs of the oscillator, and my meter can read up to 60mhz. Is that more or less the proper way to read frequency on an oscillator, just directly across the legs?
Basically a short circuit due to battery corrosion burnt the 12v power connector completely through the motherboard. As far as I can tell I've successfully repaired the damage but previously it would boot to a "floppy drive failure" message; now I get nothing on screen.
I have spent hours and hours checking for shorts and bad traces and everything looks fine, I get 12v, 5v where I expect to get 12v, 5v.
I suspect one of the oscillators that was submerged in vinegar during my cleanup attempts might have gone bad.
Also, on the bottom oscillator in this photo, do you think that's 16.000 or 76.000 with part of the 7 gone?
The attachment oscillators.JPG is no longer available
Reply 1 of 14, by retardware
keenerb wrote on 2021-10-11, 13:33:
No, because you usually will stop the oscillator with that additional capacitive+resistive load.
Or you'll change its frequency to another harmonics.
So, tap its output.
Never have seen a 76MHz crystal. But 16MHz ones are common.
Reply 2 of 14, by keenerb
That's how I felt about the 16 vs. 76 as well, I've never seen a 76mhz on a board before. I'm going through and re-checking all my trace fixes and maybe replace that 16mhz oscillator. There's a much smaller round osc that I can't find any identifiers on, that might not be fun to troubleshoot...
Reply 3 of 14, by retardware
keenerb wrote on 2021-10-11, 15:10:
These are usually the 32,768Hz crystals for the RTC. It is non-critical. If it doesn't work, the RTC will be frozen in time.
Reply 4 of 14, by Deunan
With decent voltmeter it is usually possible to just measure voltage, it should read somewhere in the middle of the Vcc if the circuit is running. Yes, sometimes the parasitic capacitance of the probes can stop a low-power oscillator but usually even direct testing of the crystal pins works.
Stopped RTC can have some annoying side-effects like some programs freezing, and DOS kernel plain rejecting the time/date set and reverting to built-in defaults. And BTW I have had a case where I actually "broke" an oscillator circuit after washing the PCB. Turns out some wet dust got between crystal pins and dried there, and (when the air was not dry enough) had enough moisture and salts in it to conduct just barey enough to load the crystal down and stop it. It went away after I brushed the PCB clean again before soldering a new part in, and realized that could be the cause.
Reply 5 of 14, by dataino.it
With the system on I don't get any frequency readings across the two legs of the oscillator, and my meter can read up to 60mhz. […]
can u post a pic of the full board ?
and above all a detailed photo of the damaged area
Reply 6 of 14, by keenerb
Sure.
It booted but had a disk failure message with the burnt 12v connectors. After cleaning it, and before re-connecting the 12v it stopped booting.
I have identified one broken trace but it seems related to the missing battery charging circuit, and the batter has been gone for some time.
CPU gets warm and I get +5v and +12v, but now that I'm double-checking I dont seem to have -5v and -12v coming from power supply; checking those to ground just reads 0.
The attachment full board.jpg is no longer available
The attachment burnt side one.JPG is no longer available
The attachment burnt side two.JPG is no longer available
Reply 7 of 14, by dataino.it
the 37c65 chip (floppy controller) is missing or did you remove it to check the tracks?
Reply 8 of 14, by keenerb
Yeah that was only while I was inspecting it. It's in-place now.
Reply 9 of 14, by keenerb
On the ISA slot OSC is around 11khz and cpu clock is 3.66mhz.
Isn't that around 3/4 what I'd expect to see on those pins?
I may be looking at the wrong oscillator being bad.
Reply 10 of 14, by dataino.it
the 37c65 chip needs a 16 Mhz clock on PIN 23 and it is certainly generated by the nearby components (74LS04 + the resistors and capacitors) check on the 74LS04 pins if there is a signal
Reply 11 of 14, by dataino.it
it is a hypothesis of a circuit, the photo is blurred and it is not possible to follow the tracks
Reply 12 of 14, by retardware
Ouch, that's a big hole. And C10 looks funny. Must have smelled nice.
Reply 13 of 14, by keenerb
yeah I replaced all the capacitors in that area as well.
i'm going to replace the 28.63636mhz crystal that feeds the FE2010A; that's where the CPU clock and ISA OSC signal are generated, so maybe that's the problem.
Reply 14 of 14, by maxtherabbit
keenerb wrote on 2021-10-11, 21:12:
i'm going to replace the 28.63636mhz capacitor that feeds the FE2010A; that's where the CPU clock and ISA OSC signal are generated, so maybe that's the problem.
sounds like it, OSC should be exactly half of that
