Reply 120 of 237, by pan069
- Oldbie
Vaudane wrote on 2021-09-16, 00:50:pan069 wrote on 2021-08-15, 22:05:Did some searching and yes, definitely had one of those. It was the last CRT I had before moving from The Netherlands to Austra […]
Martijn1974 wrote on 2021-08-15, 19:41:Yes they are.
iiyama Vision Master Pro 17" DiamondtronDid some searching and yes, definitely had one of those. It was the last CRT I had before moving from The Netherlands to Australia. Can't recall what happened to it, it's been more than 15 years, was impossible to take with me. Probably ended up in the trash... 🙁
Are these the CRT's that had a faint dark horizontal line toward the lower end of the screen? Somebody told me that two pieces of tube had to be welded together because they couldn't manufacture the panel in one piece. Not sure if that was BS or not. I do remember the picture on this display was really good.
(not mine, just a random photo on the Internet)
I purchased not even a month ago a complete-with-box vision master 404. Fantastic monitor. Does up to 1600x1200@80. Wanted to use it on my main PC but getting a digital RGB to analogue RGB adaptor which goes above 60Hz is a right PITA.
That's great. I'd treat myself to that if I had the opportunity. 😀
