Reply 41100 of 58419, by Munx
Found a Voodoo3 1000 and a Yamaha YMF719 sound card in a box-o-junk for sale.
Also an in-box Radeon x1950 pro AGP, although the box was completely trashed. While not a "real" agp card, it will certainly come in handy.
The attachment P_20211113_125313.jpg is no longer available
The attachment P_20211113_125308.jpg is no longer available
My builds!
The Underdog - The budget K6
Reply 41101 of 58419, by MN_Moody
Thermalwrong wrote on 2021-11-12, 22:43:
bjwil1991 wrote on 2021-11-11, 21:09:
Bought a Panasonic KXL-D745A with the interface card, manual, driver diskette, power brick, etc for a bit less than the asking price.
Seller's photo:
Ooh, it's the one with sound, those are so hard to come across 😀 Wish I had at least one PCMCIA with sound, my selection of 486 laptops could use a soundcard to share between them (might get a covox thingy at somepoint)
I've found the Serdaco parallel port sound solutions well suited to old 386/486 laptops, while you don't get the digital audio features (rare among already rare PCMCIA sound cards also) you can get OPL2/OPL3, Covox, Tandy-3 voice or even General MIDI music capabilities at a reasonable price.
Reply 41102 of 58419, by MN_Moody
This was a scrap bin rescue, regrettably the rest of the machine around it was likely crushed to bits a few days earlier. I've never come across another 2" floppy drive, looks like this came out of a laptop of some sort. Top cover and bezel are slightly smashed but I was able to eject the disk for the photo, 2.5" SSD shown for scale.
Reply 41103 of 58419, by RetroPC_King
that 2 inch floppy came from a Zenith MiniSPort 8088 laptop.
Reply 41104 of 58419, by Turbo ->
Munx wrote on 2021-11-13, 13:02:
What are you talking about? That card is beautiful.
Reply 41105 of 58419, by subnet_zero
Was at a local thrift shop today and got this A4Tech WinEasy 4D Mouse with 3 Buttons, 2 wheels and 1 ball for 2.50 €. It is working fine and after searching for the right drivers, also the second wheel works as intended.
It looks quite dodgy for me with those two wheels, but it feels very well while using it. The software lets you choose what function the 2th and 3th button should have, including opening up a customizable shortcut menu.
What fun little device.
Reply 41106 of 58419, by subnet_zero
I also bought new old speakers in the box: Quadral SM 480. I have no clue if they sound any good, the box says that they have 20/30 watt (DIN) and 480 Watt (PMPO). They are huge (30cm), but don't weight much. Back in the day this was a bad indicator. I remember all speakers I could afford were cheap and only with PMPO watts marketed. But those speakers were not cheap back then, 149.00 DM says the label on the side of the box. The speakers might be from 99/2000, then that's 105 € (120 USD) today.
However they are beige, unused, in excellent condition and doesn't look half bad as other speakers from end of the 90ies early 2000 I could get here, so I bought them.
I'm not sure what to do with them, use them regular or keep them original in the box? 🤔 Maybe I will try them out and put them back in the box.
Reply 41107 of 58419, by Claris
Also an in-box Radeon x1950 pro AGP, although the box was completely trashed. While not a "real" agp card, it will certainly come in handy.P_20211113_125313.jpgP_20211113_125308.jpg
Whats up with Voodoo 3s ending up in alot of junk/untested bins? I found one at RE PC a few days ago. You got yours from a bin. Iv hears of other people stumbling across Voodoo 3s in a similar manner.
Are V3s just not as desirable as V1/2?
Reply 41108 of 58419, by PdXY
I found this cl5426 card, german but unknown to me:
The attachment IMG_20211113_190819.jpg is no longer available
Reply 41109 of 58419, by imi
I didn't know they also made "topless" graphics cards ^^
Reply 41110 of 58419, by PdXY
imi wrote on 2021-11-13, 18:17:
It says "topless dies made in Germany" 😀 It has QC "bestanden"!
Reply 41111 of 58419, by MN_Moody
Claris wrote on 2021-11-13, 17:56:
For the uninitiated it's pretty easy to overlook Voodoo 3 & Banshee cards, a lot of cards in that same era used similar looking heatsinks or fans (in the case of the Banshee) ... the little 3dfx logo on the back can be the only tell sometimes that you're dealing with one. The earlier cards didn't have heatsinks covering the chipset that prominently displays the 3dfx logo.
Also, keep in mind that these cards tended to overheat in poorly ventilated cases, a lot of them went into scrap bins for a reason.
Reply 41112 of 58419, by Joakim
Bought a slot 1 system with a beat up case from an old lady. These were the components.
Epox EP-BX3 (needs a recap)
p3 450 MHz
Nvidia tnt2 64 32 mb
Ct4810
surprised me that it had a the ata133 card. Is it faster than the mb connectors maybe.
Reply 41113 of 58419, by Munx
In my experience, Ive found about as many Voodoo 1s in scrap electronics piles as Voodoo 3s. Not Voodoo 2s, though. Only found 1 localy and it came with its passthrough cable and driver disk.
My builds!
Reply 41114 of 58419, by HanJammer
PdXY wrote on 2021-11-13, 18:12:
I found this cl5426 card, german but unknown to me:IMG_20211113_190819.jpg
Wow, I love how the RAM is installed in a SIMM module. I was thinking today that I've never seen a graphics adapter with memory in SIMMs... and here it is a few hours later in this thread 🤣 😁
Reply 41115 of 58419, by PC@LIVE
Purchased a batch of motherboards to be repaired, most are SKT478, an LGA775 and a SKT462 / A, also there is a VIA chipset which I don't know if it's a 370 or a 462. In a couple there are CPUs, I don't know however what they are, most have capacitors to replace.
These are the models that I detect looking at the images:
Asus P4S800-MX
Intel 865 Perl
NSI Siemens?
ECS P4M890T-M2
ASRock K7VT4A PRO
SKT 370 ???
They cost € 3 each including shipping, about the equivalent of $ 15 or less.
I think if they only have a capacitor problem, they can fix at least half of them, or more.
When they arrive I'll try to try the ECS, which visually looks fine.
In the next few days the seller should ship.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 41116 of 58419, by Brawndo
Is that two 4-pin power connectors I see on the end? I have an X1950 Pro as well (HIS if memory serves) and it has a single 6-pin power connector.
Reply 41117 of 58419, by BitWrangler
Looks like. Makes sense though an AGP only system might not be expected to have PCI-E power connectors
Reply 41118 of 58419, by Munx
Turbo -> wrote on 2021-11-13, 15:10:
Not sure what you mean.The x1950 was sold in its original packaging. The card itself is in great condition, but that carboard box was all torn up and barely holding itself together.
It is also not a true AGP card as it uses a bridge chip, which can cause issues in some cases.
My builds!
Reply 41119 of 58419, by lolo799
Some connectivity option for a NEC sigmarion Mips-based Windows Ce device, the wifi card needs driver s installed, the Buffalo works out of the box, the Corega one isn't recognized by the integrated network drivers...
The attachment 20211110_204024_1.jpg is no longer available
Two used USB floppy drives, a regular 1x speed model and 2x speed model, definitely faster but making more noise. The 1x is not as yellow as it looks like on the picture, phone camera default settings are to be blamed for that:
The attachment 20211110_204154_1.jpg is no longer available
The attachment 20211110_204920.jpg is no longer available
