First post, by spambacon
Hi Guys. I recently got a Micro ATX AMD Board wih an Athlon 64 and i was going to build a LAN rig with the parts.
However, i'm disappointed with the selection of decent, small cases on eBay.
I have specific wishes for this hypothetic case: It must be a tower case, no cube Case and no desktop breadbox. It has to be smaller (read lower) than the typcal midi towers of the era. I want a case that is not much higher than the full height of the mATX Board and is placing the power supply "on top" of the CPU, kind of like they did with the Aptiva Cases from around the millenium. I would use an Aptiva but they are full ATX and are not much lower than the normal midi tower. Most mATX cases are placing the psu on top of the board. Also, it should be aera appropriate, bonus if beige and slightly
I would love an Asus Terminator, but there are none to get here in germany.
I am specifically looking for low cases, i dont care if they are slightly wider to make room for the psu.
Does anyone know such a case by name or model number?
I am buying in germany, but i am willing to shop elsewhere in the eu, if that helps.
I very much like the look of this case:
