First post, by Al_bundy
Hi, i would like to integrade a Radeon 9600 Pro on my Sockel A System under Windows 98 SE.
I tried a standard Risercard like this:
But my PC dont detect the videocard.
Then i insulate the Risercard. Finally i can install the driver and the PC detect the videocard.
But if i start 3dmark 2001, the pc freeze after few seconds.
I edit my AGP voltage from 1.5V to 1.7V already. But i have still freezes.
My last chance is an other AGP Risercard like with a platine or a factory insulated risercard.
Here i find all what i need. But i dont know if it really works.
http://adexelec.com/agp-single-risers
Especially the AGPFlex-02 is interesting. But its a big risk bcoz the shippingcost from USA to Germany is 100USD. 🙁
Had someone build a PC with a flexible AGP Risercard? Or have someone a solution for me?
Its one of the last step to finish my project. I had such problem also with PCI Risercards. Some works, some not.
So i hope a good AGP Risercard settle my problem.
Enclosed a pic of my system and the insulated risercard.
