Another PS/2 Mouse ISA (ISA8) card adapter
Reply 200 of 279, by Yoghoo
Unfortunately I don't get this card to work stable. Thought it only happens in Windows but I found out it's also not stable in DOS. Played with dozens of different DOS and Windows mouse drivers and tried changing the options on the card (mousewheel/speed). Already tried different mouses as well. It just hangs the mouse after an unspecified amount of time. Think I have to switch back to my original serial mouse as I am out of ideas. 🙁
Reply 201 of 279, by feipoa
If you set the mouse to COM1, did you remember to disable COM1 in the motherboard's BIOS, for example?
Reply 202 of 279, by Yoghoo
feipoa wrote on 2021-09-28, 21:17:
Yes. I disabled it (with jumpers) on the controller card. I also tested it on COM2 (with COM2 disabled on the controller card). Same problem unfortunately.
Reply 203 of 279, by feipoa
I assume you have no other device using port 3F8h, that is, assuming you have the I/O card set to 3F8h? Perhaps you can try another address and remove all other expansion cards.
The one issue I ran into was on my NexGen board. Even though I had disabled COM1 in the BIOS, Windows95 keep re-enabling the MB's COM1. I had to manually tell Windows to disable COM1 always for the conflict to resolve. This issue was with this board only.
However, if you experience the issue also in DOS, perhaps you can test the unit on another motherboard to narrow the issue down further.
Reply 204 of 279, by Yoghoo
feipoa wrote on 2021-09-28, 22:38:
There are indeed no other devices using the ports for COM1 and COM2. I did remove other expansion slots before already but to no avail.
Unfortunately I don't have other motherboards to test. I am open for donations though. 😉
Reply 205 of 279, by HBI
Belly1986 wrote on 2021-05-23, 07:08:
Rio444 wrote on 2019-12-19, 14:31:
Yes, the card is fully assembled. The price when paying using Paypal is $ 25 (if you pay as a family/friend, i.e. without a tran […]
The price when paying using Paypal is $ 25 (if you pay as a family/friend, i.e. without a transfer fee). Additionally, for shipping, $ 7 for one card and $ 9 for 2 or more.
Delivery time varies greatly by country. It seems the longest delivery time to Canada - about 1.5 months. To Germany and UK it is approximately 2 weeks. Shipping to the USA usualy takes a little more than 2 weeks.
If you name the country and I sent there, I will tell you how long the delivery took.
Here is the adapter Guide download/file.php?id=70920
I believe it will help you answer some of the questions.
Also see here Another PS/2 Mouse ISA (ISA8) card adapter
Greetings, I am new here 😀
I would be interested in purchasing a couple of these adapters but being new as a registered member I'll email you using my username as a reference. Kind Regards, -- Tom 😀
Same same, Rio444. Will send an e-mail. This is a really cool adapter.
Reply 206 of 279, by jimmystikx
Are these still available? I'm in the process of gathering parts to build up a 486. This would be a nice addition to use the ps2 optical mouse I have.
Reply 207 of 279, by Sphere478
Rio444 wrote on 2021-01-17, 18:19:
Yes, please write to me in PM. […]
kuenzign wrote on 2021-01-14, 00:09:
Rio444 wrote on 2020-06-27, 09:23:
Yes, there are adapters available. You were the one who emailed me, weren't you?
Do you still have cards for sale?
Now adapters has a new revision - 1.2 .
Changes in revision 1.2 compared to revision 1.1:
- added support for Windows 2000 and Windows XP,
- changed layout of jumpers and marked position of jumpers to select COM3 and COM4,
- removed data rate divider 1/3 (only 1/2 and 1/4 remain),
- added the ability to select any IRQ from the range 5, 6, 7, 2/9.
A card like this would be preferable on older systems over usb yes? Because of usb input slowing down cpu?
How hard would it be to add a kb port?
Lots of old mobos out there with broken kb ports.
Sphere's PCB projects.
Reply 208 of 279, by Rio444
Hello everyone again!
Yoghoo wrote on 2021-09-26, 18:34:
Thought the problem was gone by switching to COM1 but unfortunately above problem also exists on COM1. @Rio444 do you know why this is happening?
If the LED is on continuously and does not blink, it means that the driver has removed the signal from the RTS of COM port (in this case, virtual COM-port), i.e. disabled the mouse.
It's hard for me to guess why this might happen.
Try to use other drivers, both built into Windows and third-party. For example Genius drivers.
jimmystikx wrote on 2021-12-07, 20:00:
Adapters are usually available. Only I do not always have time to make them, so sometimes they run out.
Due to the growth in the cost of parts and postal services, the price of adapters has slightly increased. One adapter now costs $ 27. Postage for one adapter costs $ 7.5, shipping 2-3 adapters costs $ 10.
If I didn’t reply to the email, it may not have arrived. In this case, write to the address riv.rostov(a)gmail.com
I check this mailbox less often than the main one, but the chances that the letter will reach is higher.
If it is possible to install a USB port, then it is usually preferable, although it slows down the system a little.
The keyboard port cannot be added, because its address don't go on the ISA bus.
At the same time, the keyboard port is usually easy to repair. The problem could be with the strapping or the controller.
You can see how it works in the datasheet for keyboard controllers. It usually looks something like this:
Reply 209 of 279, by digger
You always know you're working on a really awesome project with high demand when you see multiple newbies (or longtime lurkers?) inquiring about it in the first post they make on the forum. 😁
Welcome all! 🙂
Reply 210 of 279, by Eldatur
Long time lurker here, I'm interested in 1 or 2 of these cards. I sent you an e-mail 😀
Reply 211 of 279, by Yoghoo
Eldatur wrote on 2022-02-18, 16:02:
Don't know where you from but these cards come from Russian. Not want to start a political discussion but with all those sanctions it can be difficult to receive them at the moment.
Reply 212 of 279, by Sphere478
Rio444 wrote on 2021-12-12, 20:14:
Hello everyone again! […]
Rio444, the time has come and I find myself in need of a isa ps2 card
I also share concern about being able to get these cards out of Russia.
I skimmed the thread, but did not see any pcb project files? Did I miss them?
If not. Are you willing to upload them?
But,
I actually have something even grander to propose though,
Calamitylime has made a rather nice external adapter that supports several protocols/ports. And I have some free time to draft pcb files.
I was wondering of between the three of us we might be able to make a project that had more features but was internal like yours. Maybe improve availability world wide also?
A collaboration.
What do you think?
Reply 213 of 279, by Rio444
Sphere478 wrote on 2022-12-22, 05:23:
Rio444, the time has come and I find myself in need of a isa ps2 card […]
It looks like the crap that some of my compatriots have done in Ukraine will not end in the foreseeable future. So yes, I'm close to sharing all the sources, but I'm not ready for that yet.
This project is no longer interesting to me. But it brought a small but stable income, which allowed me to do other projects. Over the past time, I was able to implement several small projects that I was too lazy to post on this site. And perhaps the most serious project of mine to date is coming to an end - a video converter from EGA/ CGA/MONO to VGA. It is similar to the well-known MCE2VGA project, only little better))) Here is a video of the very first prototype https://www.youtube.com/watch?v=7mMGqXjjjTI
As for the mouse PS/2 adlapter in ISA, I plan to do the following. In the near future I will post here gerbers for PCB and BOM. So that everyone can evaluate the cost and the ability to make it on their own. If someone decides to do this, he can write to me in the PM and I will give the firmwares. Please note that I consent only to the non-commercial use of these materials. You can make devices for yourself, your friends, maybe sell some surplus on the local market, but nothing more.
Added:
Gerbers https://drive.google.com/file/d/1UlZlQQGpr_lv … iew?usp=sharing copy https://disk.yandex.ru/d/h6lZCQXyhQQ--w
BOM https://docs.google.com/spreadsheets/d/1Y1JxC … of=true&sd=true copy https://disk.yandex.ru/i/KORzw5qpPurPqw
Reply 215 of 279, by arg
I bought this adapter few years ago, but only now finally managed to test it, building a new rig.
My setup: Microsoft IntelliMouse USB -> Aten CS84U KVM -> Adapter card -> Socket 3 motherboard. The adapter is configured as COM1, board's ports are shifted in a way:
COM1 -> COM2
COM2 -> COM3
Been using it for few days, no issues noticed so far.
Reply 216 of 279, by ramon
If anyone made a card and/or if it is available for sale again, I would be interested.
Tandon 286/n 286-12 | 4MB | PVGA1A-JK | ES1869F
Highscreen Pentium 233 MMX | 64MB | S3 ViRGE/DX | Voodoo I | AWE64
AOpen K6-2+ 450 | 512MB | GF MX2 400 64MB | SB Live!
Reply 217 of 279, by Gasmart81
I´m also interested in a couple if someone makes them.
I want to use the PS/2 IBM TouchSelect touchscreen for my 8513 display in my good old Juko XT clone.
Many thanks and greetings from Argentina!
Gastón.
Reply 218 of 279, by POTA
I just found this project, would have loved to try one. Are they as responsive (lag wise) as native PS/2 mouse m/b support?
Reply 219 of 279, by feipoa
POTA wrote on 2023-06-23, 11:30:
I've used 5 different external ps/2 to serial protocol converters, all of which showed some lag when used with my KVM at the tested resolution, normally 1280x768. With Rio444's ISA serial emulator card, I did not observe any lag. Rio444's emulator card is my go-to for all systems for which I cannot modify to accept a native PS/2 mouse. It is my opinion that everyone should keep at least one of these cards for such circumstances.
I have only two of Rio444's cards - one is in my NexGen PF110 system, the other I use for benchtop tests.
