Reply 41520 of 58450, by PcBytes
- l33t
TrashPanda wrote on 2021-12-17, 07:42:Just found a Freeway FW-6400GX / 150 Slot1 + Slot 2 board on eBay ...Slot 2 takes the PIII Xeons right ?
Im now wondering if I can shove one of the PIII Xeons I have in it, if so ..I might just buy it.
As far as I could find, it should support it. If m1919 is reading this, let us know if your mobo could run the P3 Xeon out of the box, or if there was anything else needed to get it running.
Speaking of which, that board could very well make a killer machine, even if it isn't dual Slot 2.
(the only ones I know of is EPoX's GXB-M and the ASUS XG-DLS)
Wonder how the 440GX would fare against standard BX.
Onto the main topic, I've won YET ANOTHER Gericom lappy. Here are its specs, these things are just pure awesomeness. OEM'd by Uniwill/ECS, model G730, so likely a recap might be in order, but I'll have to see.
Pentium 4 2.5GHz (likely an nice Northwood core due to 512kb L2 cache, Prescotts usually have 1MB if my memory serves me right) desktop chip
Intel i845 chipset (not sure what kind though, all I know is it's using SDRAM so likely the original 845 iteration?)
512MB RAM
Radeon Mobility 9000 (aka M9)
40GB HDD
WinXP
