Getting files to CP/M-86
First post, by squelch41
Im trying to get some modem/teminal software onto a CPM-86 "disk"
I'm booting CP/M-86 using the serial port disk in XT-IDE (I dont have a real floppy drive) which works fine.
However, I need to get a serial transfer program onto a CP/M disk to run.
I was hoping I could just use dos but, of course, CP/M disks cant be read in dos.
22DISK wont recognise any drives on my machine and, in virtualbox, always returns write errors (using a 360k and 720k disk image)
Does anyone have a CP/M-86 floppy disk image with eg. modem9 on it? I've got all the files, just no way of actually getting them on to a CP/M disk image!
Thanks!
V4P895P3 VLB Motherboard AMD 486 133MHz
64mb RAM, CF 4Gb HDD,
Realtek 8019 ethernet + XT-IDE bios ROM, ES1869 soundcard, VLB Cirrus Logic GD5428 1mb VGA
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
Reply 1 of 4, by darry
Have a look at cpmtools
Reply 2 of 4, by Jo22
Hi! DOS Plus 1.2 might be able to read both FAT12 and CP/M file systems, also..
It's essentially CP/M 86 with a DOS emulator built-in (PC MODE).
How to install DOS Plus (PC1512 version) ?
https://www.youtube.com/results?sp=mAEA&searc … ry=Dos+plus+1.2
Good luck! 😀
Reply 3 of 4, by squelch41
Jo22 wrote on 2022-01-12, 14:30:
Good luck! 😀
dosplus worked like a charm!!
thanks!
Reply 4 of 4, by Jo22
You're welcome. ^^
