Reply 3440 of 5107, by Repo Man11
- l33t
Repo Man11 wrote on 2022-01-19, 04:52:Recent Craigslist free section scores: A Hiper Type M 730 watt power supply that I haven't yet tested, though it powers on with a paper clip. https://www.newegg.com/hiper-type-m-hpu-4m730 … N82E16817128008
But my score this evening was a good one: an Asus Z87-K motherboard with 8 gigs of HyperX DDR3, an i5 4670K, an R9 280X, and a Thermaltake case. With a test install of Windows 10, so far everything is working well.
Edit: sadly, the video card locked up just barely into a run of 3D Mark. I pulled it out and cleaned it, lubed the fans, and reapplied thermal paste, but now I get no display unless I use the onboard video. Ah well, easy come, easy go. I didn't expect it (the video card) to work at all as the Thermaltake case has a handle on the top, and the video card was stuck in the gap between the handle and the case when I picked this stuff up.
I gave up on the video card last night, but made a few more tries today. It would work, then when I'd try to reboot, I'd have no display. I discovered that when it was working, though it is a PCIe 3.0 x16, it was in x4 mode? I took it out and very thoroughly cleaned the slot contacts; since doing that it hasn't failed to boot up properly, it's in x16 mode, and I've been able to run 3D Mark repeatedly with no issues.
