Reply 20880 of 30906, by fool
Bought dozens of old laptop processors just because I saw one Athlon XP-M 2500+ in the picture. In the end there was two of them and also couple of PIII-S tualatins (1.26 + 1.4) for my surprise.
Also found one S754 Turion 64 so I was able to test S939/S754 combo mainboard I got for free some time ago. Intel socket 478 cooler fits nicely in the bracket and takes contact to silicon. Proper S754 cooler left hanging too high due to bracket fasteners. I don't own a S754 build yet so this will become one.
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 20881 of 30906, by pentiumspeed
I did not realize this works using socket 754 mobile processors in place of regular socket 754 processors?
Cheers,
Great Northern aka Canada.
Reply 20882 of 30906, by fosterwj03
I spent some time this weekend installing, and then re-installing OS/2 Version 2.0 (with Service Pack 2) on my Retro Overkill Pentium 4 system. Here are the specs I used:
- Pentium 4 2.8GHz (Northwood)
- Industrial Socket 478 Motherboard with ISA
- 2GB of DDR RAM
- ATI Graphics Ultra Pro (PCI MACH32, 2MB DRAM)
- D-Link DFE-500TX Network Card (PCI)
- Sound Blaster 16 (CT2230) with Dream Blaster S2
- Generic DVD Drive (EIDE)
- Generic CD-RW Drive (EIDE)
- 16GB SD Card in a SATA Card Reader to a SATA-to-IDE adapter
I know OS/2 can get pretty fiddly, but Version 2.0 seems to be about the worst. It doesn’t have any CPU speed issues with the drivers, but the kernel fails to boot every other time from the install floppy and about once in 5 boots from the SSD. No worries, I just keep restarting the system until the kernel boots. It also refused to format a 2GB partition with HPFS (and FAT for that matter) during the installation process. I ended up formatting the 2GB partition with DOS 6.22 first, and then installing OS/2 to the drive without formatting the partition it again.
I also learned that I should install the ATI graphics drivers after updating OS/2 with the Service Pack (Fixpak?). ATI had slightly different drivers in the package for OS/2 Versions 1.3, 2.0 GA, and 2.0 with the Service Pack. Installing the Service Pack completely messed up the graphics. I had to re-install the OS to get it right. Regardless, seamless Windows won’t work with the ATI drivers, unfortunately.
I still need to install networking and TCP-IP (even if the best I could do is FTP with it). I also need to figure out how to get the SB16 working in a DOS box. So far, I initialized the SB16 in a DOS session, but programs (such as Doom and Epic Pinball) crash when starting their sound drivers. Oddly, if I use the PC speaker for sound FX, I can get General MIDI to work in Doom.
I’m also a bit disappointed that the version of Windows 3.0 that came with the OS/2 install disks doesn’t include any Windows utilities, including File Manager. It’s almost useless. I copied the utilities from a Windows MME installation into the WINOS2 directory which helps a bunch.
I will say that OS/2 runs really fast on a Pentium 4. I also found IDE CD-ROM drivers on virtuallyfun.com that work really well with both of my drives. While I installed from floppy images and a Gotek, I bet it could install from CD-ROM a lot faster if I made a directory for the hard drive style installation and copied the files to CD. Maybe I’ll play around with that next.
Reply 20883 of 30906, by X86
Does this count as a retro activity? i finished building this ar15 the other day. Its a design back from the late 50's 🤣
The attachment ar15.jpg is no longer available
Reply 20884 of 30906, by creepingnet
Setup some more e-bay auctions for stuff. Finally thinning the herd. I'm going to keep going till I run out of boxes or feel like I've minimized enough. Not doing systems for awhile though.
Looks like the AMD K6 on that motherboard won't fit the NEC Ready 9522 (socket 5, not 7 - missing a pin), so going to look at some other upgrade CPUs for that one to see if I can push it to the limits.
~The Creeping Network~
Reply 20885 of 30906, by ODwilly
Going to pull out and setup the P4 for the 1st time in ages. Finally have a not dead PCI wifi card, and a spare vga input on my monitor. Pics and a thread on the Pheonix coming to life for a 4th time maybe? Stupid board just wont die.
Reply 20886 of 30906, by Doornkaat
fool wrote on 2022-02-06, 18:43:
ASRock made all those weird but good motherboards back then! Always nice to see.😃
Reply 20887 of 30906, by appiah4
Turbo -> wrote on 2022-02-05, 21:01:
Spent the whole day restoring this beautiful butterfly: vacuuming, cleaning, setting up Mhz display, lubricating bearings, installing DOS, troubleshooting interrupts, setting up sound, cleaning again, etc...
Did that case come with the U5S-40 or did you put that in? Jealous. I really want a U5S-40 😒 Only have a 33.
Reply 20888 of 30906, by RandomStranger
Today I sort of tested some of my recent finds.
1. A Trust PS/2 optical mouse and the vintage market Rage Pro Turbo.
My AGP test bench booted, Windows 98 SE set up its built in drivers, reboot, and now within a minute after Windows boots it freezes. No matter if I disconnect the mouse or replace the graphics card. My guess is that something broke the Windows. The system was already unstable when I was trying to game-test my Savage 4 Pro a couple of weeks ago. Otherwise the mouse works fine and the Rage Pro Turbo posts so I take this as a win.
2. The turn of the SB0220. The AGP test bench boots with it, adjust the drivers I've installed for the SB0060. The sound card is detected correctly, but because of the system's instability, no further tests were done.
3. The 2x256MB DDR RAM. The test bench boots with either and both of them.
I think tomorrow I'll re-flash the CF with a fresh Windows 98 and give another go for the cards.
Reply 20889 of 30906, by BitWrangler
appiah4 wrote on 2022-02-07, 18:16:
Save up your wishes for a U5D or U486DX2 at least 🤣 ... there's a U5S-40 on evilbay on a chaintech board if you're desperate.
Reply 20890 of 30906, by Jed118
I found another SB0220 so I installed in a PIII 1.0 I'm selling - now it is fully SB compatible, even in DOS.
I also retrobrited a keyboard (it was sunny today) and it came out 10x better than it was.
What's for sale? my eBay!
Reply 20891 of 30906, by stef80
Straighten the pins of a least half a dozen Tualatin Celerons and Pentiums I had lying around.
Tools to use:
* spare slocket adapter
* mechanical pencil with metal tip (Rotring Tikky 0.5mm)
The attachment IMG_20220208_092834 (1).jpg is no longer available
Reply 20892 of 30906, by bjwil1991
That's one of the best tool to use for straightening pins on a CPU. Wonderful work, man.
Reply 20893 of 30906, by TrashPanda
Not retro as such but the old girl I use as my daily driver needs a bit of TLC after her PSU shit the bed so Ill be doing that after which I have a AT box that needs a system put into her.
Daily driver is a Threadripper 2950x with a 2080ti so its pretty heavy on the old Angry Pixie maker, this will be its third new PSU so this time ill be stripping the LED fans and controller out of it .. not sure if the Corsair LED controller is fully kosher, if it kills another I might just switch to using the money maker as my daily machine and retire this one to the basement as a file server.
And yes as weird as it sounds this Aussie house has a small basement 🤣. (For the ones not in the know, Australian homes dont have basements normally or attics)
Edit - 3 Hours later and the 2950x is once again happy, cool, quiet and more importantly dust bunny free. Put a Dark Rock 4 Pro TR4 on it and removed the failing AIO, shame its an Enermax or I would have tried to flush and refill it but its an Enermax TR4 and it'll be full of corrosion and algae so to the bin it goes. New PSU in too, nice 800watt Seasonic Prime Platinum.
Dropped Core temps on CPU from ~50c Idle to 38c Idle...yup that AIO was shot to shit glad I replaced it now before it failed totally.
Oh and its LED free now too, no more lovely red glow but the LED controller was likely the culprit for killing the other PSUs.
Reply 20894 of 30906, by debs3759
stef80 wrote on 2022-02-08, 08:38:
Straighten the pins of a least half a dozen Tualatin Celerons and Pentiums I had lying around. Tools to use: * spare slocket ad […]
Tools to use:
I use a thin knife to get pins mostly straightened, then blunt tipped syringe needles of various sizes (depending on size of pins) to finish the straightening if needed
Reply 20895 of 30906, by TrashPanda
debs3759 wrote on 2022-02-08, 18:31:
Tools to use:
Credit Cards works nicely too, the only pins I hate trying to straighten are LGA socket pins ...need a loupe and micro tweezers for them.
Reply 20896 of 30906, by rkurbatov
I wanted to buy just the desktop case, but when the seller showed me what's inside I've decided to buy the whole PC. It's Asus P/I-P55TP4XE with that rare Asus Media Port and I decided to make it the base of my Pentium 1 build. The mobo didn't pass the boot test, so I extracted all the chips, washed carefully and tried once more. It made beeps and it's alive! And luckily I've found the 256 KB of COAST cache at one of the shops. So I'm happy to have such a nice thing. I'm considering the Pentium MMX Overdrive option. Or maybe will put original P166 (now it has P100 for test).
Another nice achievement is increasing the VRAM size on my VLB videocard from 1M to 2M. I had only 1MB of video on my Alliance ProMotion DSV6422 and wanted expansion so badly to have 800x600x24 bpp. Now I have this closure!
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 20897 of 30906, by stef80
TrashPanda wrote on 2022-02-08, 18:37:
Tried credit cards. OK for whole line of slightly bent pins, but not for ones that are bent hard. 0,5mm mechanical pencil tip works great for those.
As for LGA sockets, I used phone camera and hypodermic needle.
Reply 20898 of 30906, by TrashPanda
stef80 wrote on 2022-02-08, 20:53:
Phone Camera .. why didn't I think of that, im guessing with a phone stand cause 4 hands I dont have.
Reply 20899 of 30906, by debs3759
Tools to use:
I had to straighten a few pins on an 1150 board. Used a loupe (40x magnification) and the tip of a very sharp knife (so a pointy razor, in effect). Horrible job, but it looks OK. Yet to test it though 😀
