Reply 20 of 20, by rmay635703
rmay635703
Offline
- Oldbie
Too bad a
Buffalo/Melco Hyper memory module interposer doesn’t exist for CPUs other than the 386DX
You could just dump more memory into the cpu socket independent of the chipset
Also nice would be a vlb or PCI memory expansion device, said device would run roughly the same speed as 60ns memory and likewise would allow nearly any amount of memory to be installed
Sadly the only PCI memory expansion device was very late for virtual memory ran through the hard disk controller, making it pretty useless
