First post, by DaveDoc1984
Hi, I am new here but not new to the world of Retro PC's
Many many years ago my family had a 486 machine manufactured by a UK based company called Time Computers. I am in the process of building myself a similar specification machine to that from my childhood. I have bought various components to get a system up and running (hopefully).
However, I am struggling to track down details of the Motherboard I have got which has a marking of md-4duv-ver 2.1 on it and has UMC chips on the board.
Below is a picture of the board that I have found, I would like to try and track down a user manual for this so I can make sure I set the Jumpers up correctly.
https://thumbs.worthpoint.com/zoom/images1/1/ … de9acb5626e.jpg
Reply 1 of 26, by snufkin
maybe this is the board: https://www.ultimateretro.net/en/motherboards/640#downloads
(listing says MB-4DUVC, but the first photo there is labelled MD-4DUV-VER: 2.1. Looks like most jumper settings are shown on the silkscreen).
Reply 3 of 26, by Horun
DaveDoc1984 wrote on 2022-04-03, 21:02:
Thanks, my only concern is have I potentially got a CPU that won't work? This board does have jumper settings for 486DX and DX4 but no mention of DX2 which I have bought a Intel 80486 DX2-66?
Yes it does, the CPU jumpers for a Intel DX2 are same as Intel DX and AMD DX2. Only if an SL cpu are they different and the voltages could be too.
For Intel DX2-66 use the 80486DX or AM486DX2 cpu settings, you will notice they are identical. Just be sure to set CPU volts to 5v as Intel DX2 are all 5v AFAIK.
There are some AMD DX2 that are 5v and some are 3.3v....
Reply 5 of 26, by DaveDoc1984
Sorry to ask another question but I am very confused. The motherboard Manual linked here makes reference to Jumpers that don't appear on my board at all e.g. I can't find any Jumpers marked up as J30, 31, 32, 33, 34 and 35.
Also the Silkscreen doesn't mention DX4 yet this manual does and gives jumper settings for it, does it support DX4 (if I was to get a DX4 CPU in the future) or no ?
Reply 6 of 26, by waterbeesje
Cool! That's the same board I have! Aquarius brand 😀
I can confirm the jumpers do match the link and it does work with almost any CPU you throw at it.
I've ran it with an SX, DX, DX2 (DX setting), DX2-SL (at 3v) DX4 (Intel and amd), 5x86 (amd and cyrix).
5x86 does display weird post strings (like SX-66) but it works flawlessly.
Stuck at 10MHz...
Reply 7 of 26, by DaveDoc1984
waterbeesje wrote on 2022-04-07, 20:39:
Cool! That's the same board I have! Aquarius brand :) […]
Thanks so a DX4 will work?
I can't find JP35 etc though?
Reply 8 of 26, by snufkin
Just had a closer look and it turns out there are differences between the DUV and DUVC where they shifted one of the two big jumper blocks by the CPU to make way for the voltage select jumpers. You can make them out in this photo of the DUVC: https://i.ebayimg.com/images/g/KlEAAOSw0R9gRC49/s-l1600.jpg (looks like the design allows for either 30 or 72 pin RAM sockets).
So the jumper manual for DUVC won't be a lot of help. There may still be some options for voltage selection. Look for connections between any of the blue resistors, the jumper pins and the voltage regulator. In the photos of the DUV version it looks like there are 3 blue resistors, which are higher precision than the usual resistors and often used for setting the output voltage of an adjustable regulator.
Reply 12 of 26, by DaveDoc1984
Figured it out. The same Voltage Jumpers referenced in the DUVC manual appear to set the VCC to the CPU to 3.3v on my DUV board so that is good.
Just now need to know which other jumper settings to set for a DX4.
Reply 13 of 26, by DaveDoc1984
So figured out the DX4 settings and its working. Shows DX4-S on boot up and 100MHZ
Next question, where on earth do I connect a CMOS Battery? There is nothing onboard (no battery compartment or terminals) so how would I do this?
Reply 14 of 26, by Babasha
DaveDoc1984 wrote on 2022-04-11, 13:06:
Your motherboard photo, pls. Link in your first post is “forbidden”(((
Need help? Begin with photo and model of your hardware 😉
Reply 15 of 26, by DaveDoc1984
I have just clicked that link and it took me straight to the photo?
    196.27 KiB
    Motherboard Battery Area
Reply 16 of 26, by Babasha
1) internal battery socket place
2) external battery pins
Reply 17 of 26, by DaveDoc1984
I have run into a bit of an issue which I think is Cache Related (External rather than Internal CPU Cache).
The motherboard has a Bank 0 and Bank 1 of Cache. Bank 0 is the only set that is populated as well as the TAG.
All slots in Bank 0 have W24257AK-15 Chips in them and Bank 1 is completely empty.
I have set the jumpers to reflect that only Bank 0 is populated and from the Spec sheet of the Chips its 32k x 8 so 256K? I have set my jumpers to reflect this but the machine will start to initially boot the OS and will halt a few seconds in. If I DISABLE External Cache, the machine then works fine. Any ideas on what could be wrong? Could 1 or more of the Cache chips be faulty?
Reply 18 of 26, by Babasha
DaveDoc1984 wrote on 2022-04-12, 09:46:
I have run into a bit of an issue which I think is Cache Related (External rather than Internal CPU Cache). […]
Photo pls!
