First post, by marmotta
Hi! I have a Citygate chipset motherboard with 25mhz 286! The exact name is TD60K, same as this: https://www.ebay.com/itm/185378852274
This board stop working, I have tested all, some test... I suspect the bios is damaged. Anyone have this bios? Or where I can found it. Thanks!
Reply 1 of 30, by Horun
Can you post a picture of your board? Just because you have a 25Mhz Harris does not mean it is running at 25Mhz (I have a board with 20Mhz Harris in a 16Mhz board)...
Reply 2 of 30, by marmotta
Horun wrote on 2022-04-21, 00:18:
This is my board, which card do you have?
    1.62 MiB
Reply 3 of 30, by PC Hoarder Patrol
There are some similar (series) boards on Ultimate Retro (with BIOS downloads) - check these links
https://www.ultimateretro.net/en/motherboards/?name=td60
https://www.ultimateretro.net/en/motherboards/?name=td70
Reply 4 of 30, by marmotta
PC Hoarder Patrol wrote on 2022-04-21, 10:55:
I have already tried the td60c bios, but the diagnostic card show me random numbers… (not go, or is wrong flashed) most chip are different (keyboard and others). Td70 is for 386. My original eprom show me only “FF”, another eprom from generic 386 show me the correct pass 01/02 and stop. (is normal, is for 386)
Reply 5 of 30, by PC Hoarder Patrol
One sold on ebay the other day - https://www.ebay.com/itm/185378852274?hash=it … =p2047675.l2557
Maybe you could make contact with the buyer (thru the seller) and ask for a BIOS dump
Reply 6 of 30, by marmotta
PC Hoarder Patrol wrote on 2022-04-21, 11:39:
I have ask, but I don't hope much 🙁
Reply 8 of 30, by marmotta
Predator99 wrote on 2022-04-21, 18:09:
Please upload a copy of your current BIOS. We can see if the checksum is OK and if yes try to get it running in PCem.
I waiting the eprom reader/writer, when It arrives I try to read the bios
Reply 10 of 30, by marmotta
zapbuzz wrote on 2022-04-21, 19:32:
whenever i see a motherboard without its base memory chips i cringe that it might not have 540k base memory or is that vram?
This board can use dip or simm, I use simm. The board is always gone without dip 😉
Reply 11 of 30, by marmotta
Ok! Now I have the reader/programmer... this is the dump of original bios, seems ASCII read reveal a damaged contenent. If you want to take look 😉
    td60k.zip
    41.69 KiB
    68 downloads
Reply 12 of 30, by Horun
Looks a bit odd. The AMI header even on 286 boards should always be readable and is but have to load in PCem or MAME to see if it really is OK.
Reply 13 of 30, by marmotta
Horun wrote on 2022-04-22, 23:00:
The td60c bios available on net have the same read problem...
    2cgm001.zip
    41.69 KiB
    49 downloads
Reply 14 of 30, by marmotta
After comparison the td60c and td60k bioses seems to be identical (and same checksum). My bios is ok and the problem is another? But I don't know because on hex editor I cant view the correct characters (other bioses view correctly)
Reply 15 of 30, by Horun
BIOS would not load in PCem under generic AMI 286 or TriGem 286. Have had good luck loading them before so am wondering if that BIOS is odd enough or it has a major issue....
added: will try to load it in MAME later when I have time...
Reply 16 of 30, by marmotta
Horun wrote on 2022-04-23, 23:16:
Yes, I tried too. This is a strange bios and board... but I think the bios is not the real problem (if online bios is the same of my bios, I think is ok), probably the chipset is died 🙁
Reply 17 of 30, by Anonymous Coward
Do you know which chipset the board actually uses? I think "Citygate" is like "PC Chips" and "ETEQ" branding...just a sticker.
Just the other day I saw a Citygate board that was actually based on an ALD chipset.
Reply 18 of 30, by vstrakh
That is the way they've mapped the 8-bit rom onto 16-bit data bus. Some motherboards or ega cards would use two chips, this motherboard uses single chip, and the most significant address line is used as a "byte select" input. So lower half of the chip stores even bytes, the upper half stores odd bytes.
The plain content as seen by cpu would look like this:
2cgm001_straight.zip
36.67 KiB
55 downloads
Reply 19 of 30, by marmotta
Anonymous Coward wrote on 2022-04-25, 00:46:
Do you know which chipset the board actually uses? I think "Citygate" is like "PC Chips" and "ETEQ" branding...just a sticker. […]
Is Citygate d90-275, under the sticker the chip is blank. The board have another smaller chip and is ALD 93c001 from Fujitsu and i think is keyboard controller... but I not have reliable information's. This chipset is very poor documented.
