Reply 44280 of 58450, by Kahenraz
I've never tried a good scaler. I've seen a lot of them around, but it's a complex problem and have largely ignored it.
Reply 44281 of 58450, by Shreddoc
Good scalers (your Retrotinks, your OSSCs, your GBS Controls, et al) are low enough lag to not matter.
However, if we're comparing flat panels to CRTs, then the age and type of flat panel we're comparing is potentially more relevant, re: lag.
It's not my specialist area personally, but I've heard from a credible source that it's only in about the past ~5 years that panel characteristics have allowed (quality) flat panel PC screens to get into the low-lag realms that CRTs had all along. In terms of true "input port - to - visible pixel" time response.
Reply 44282 of 58450, by imi
professional video scalers have about 1-1.5 frames of lag
Reply 44283 of 58450, by Shreddoc
imi wrote on 2022-05-02, 02:15:
to quote myself, since my edit coincided with your reply: "(your Retrotinks, your OSSCs, your GBS Controls, et al)"
Lag varies by type and options selected. But, with the above mentioned scalers, is broadly considered by the gaming community to be negligible. In the scheme of things, where literally every step in the signal path can be considered to "take time".
e.g.
RetroTink 2X Classic added 53 MICROSECONDS of lag. Thats 0.053 milliseconds. It came out two years ago, and was famed for being […]
It came out two years ago, and was famed for being lightning fast scaler.
RetroTink 5X Pro adds at a minimum ~0.25 FRAMES of lag, which is ~4 MILLISECONDS.
thats with no options turned on.
Options can take it above 20 milliseconds.
While thats still much faster than TV scalers, it's SLOW compared to his RetroTink 2x classic.
Another contextual / real-world example:
Well yes, for most gaming situations 4ms is undetectable. But for hosting local Fighting game tournaments, or playing relatively high level FG, where we are already shaving off milliseconds where we can (Samsung terrace is as fast as CRT’s now), and I could scale MVC2 UP TO 1440p from a Dreamcast thru a RetroTink 2x classic & mcable gaming edition TOGETHER in 0.553ms, [0.053 for the 2x classic and 0.5ms for the mcable), then my display only added 8.9ms
That's a gamer seeing just over 0.5 milliseconds scaling lag, then having his (top-of-the-line, chosen specifically for speed) screen itself add about 8.9 milliseconds on top of that.
For reference 1 frame @ 60fps = 16.66 millisconds.
All this is to prove: with good PC/videogame scalers like those I've mentioned, lag is not an issue at all.
Reply 44284 of 58450, by Cuttoon
Shreddoc wrote on 2022-05-02, 01:14:
Yeah that stick you got is rubbish. I mean, subjectively. I'm sure it could be put to some use. But it's a far cry from what peo […]
Cuttoon wrote on 2022-05-02, 00:39:
OK, I don't know my Thrustmasters that well, just made a random search, did not check the specs. You may be right that those are […]
Shreddoc wrote on 2022-05-02, 00:28:
And the native DOS, gameport $1 Thrustmasters?
What you've posted there above is, yes, just cheap digital Win9x-and-above (or console, in some instances) "crap".
OK, I don't know my Thrustmasters that well, just made a random search, did not check the specs. You may be right that those are not old enough to be of any value "again".
Then again, the Thrustmaster stick I got last week was certainly "native DOS" - but sadly, still looks and feels like pretty cheap crap.
Re: Bought these (retro) hardware today
But, on the other hand - I bought that after it had run out three times, so even the one Euro is a shaky assessment...
Are you in the US? Everything is more expensive there and mainly, for many things, the market seems to have been swept completely while in Europe there's still a bit of a oversupply.
Voodoo cards or SB64 are the same "+3000 %" mess over here.
Yeah that stick you got is rubbish. I mean, subjectively. I'm sure it could be put to some use. But it's a far cry from what people mean when they talk about the iconic Thrustmaster days of yore.
I totally agree with you that most old joysticks are $1 rubbish. Because most old everything is $1 rubbish. Fact remains that, as with everything, there's a slim core of vaguely agreed-upon "outstanding products" out there, which retain some value through specific purpose and merit.
Even deeper, there are sub-niches where people have to search far and wide before they're able to find an ideal controller. Quite far from the utopia of $1-crap freely raining down for all, it's more of a long term mission, where sometimes even (gasp) !dozens! of $ are spent 😉
Yep, while I stand by the fact that Tie-Fighter is one of the greatest games of all time, I'm officially too clumsy for "real" flight simulators and anyway, somehow I've always refused to max out on any gaming paraphernalia - e.g., despite quite the habit during CS heydays, I never bought a dedicated gaming mouse.
So, I'm still looking forward to the time when I happen upon a joystick that feels serious to me. The logitech are really well designed and manufactured, but their inner value is nothing special. Didn't test the Wingman Extreme yet, but its haptic did not quite convince me anywhere near the "premium top of the line" price difference back then.
Both are far beyond the Thrustmaster one, for sure.
But I know what you mean - some products of any kind simply have the distinction of "If I'm going to bother with antique PC flight sticks, I may well use the very best."
Or, just learned on ebay, while vanilla or even "pro" TNT2 cards get thrown out a dime a dozen, a humble TNT2 ultra will cost you 40 €. For the distinction of being what, 10 % faster?
Sad example: Ancient 1st generation DECT Gigaset 2xxx handsets for land line kept much of their average resale value (~30 € refurbished) for well over to decades now, despite land line hardly being even a thing.
They break down eventually, as any handset will, but kept being repaired.
Because, anything that came after them, be it premium from Siemens or some Chinese knockoffs, was universally hideous, overcomplicated shite with abysmal ergonomics. Some of the later Siemens stuff was really like "your original design team would have committed group seppoku rather than allowing that crap leave a factory". Sometimes, capitalism just fails us.
I like jumpers.
Reply 44285 of 58450, by imi
Shreddoc wrote on 2022-05-02, 02:19:
yeah, hence why I said "professional" as in pro gear out of the broadcasting world ^^ what I meant to say with that is just because they used to be insanely expensive doesn't mean they're lagless, but still a lot better than most of the generic cheap stuff out there, the aforementioned are hobbyist projects specifically made to be lagless, unfortunately the retrotink doesn't really cater to the PC crowd 😒
and having low latency capture was more important to me, so I went the datapath route instead of getting an OSSC
Reply 44286 of 58450, by Shreddoc
imi wrote on 2022-05-02, 03:10:
Quite understandable. Anyway, the options are out there.
I just wanted to highlight how the lag introduced by quality scalers tends to be dwarfed by the lag inherent to flat panels themselves.
Reply 44287 of 58450, by RaiderOfLostVoodoo
Cuttoon wrote on 2022-05-02, 02:53:
And I probably had a gaming mouse before anyone else here: Razer Boomslang
But they were shitty. The left mouse button (or right, if you're lefthander or StarCraft fanatic) breaks quite fast. Had three of them, which lasted around 2 1/2 year each.
The title is funny. "Like 3dfx"... Probably to get more views. I've also seen people putting "no 3dfx Voodoo" into the title.
Top of the line always demands a premium because that's what people like us want. A GeForce FX5900 can sometimes be bought for under 50 bucks. FX5950? 200+! Or compare Tualatin 1300MHz vs 1400MHz.
Reply 44288 of 58450, by maverick85
3dfx Voodoo 3 2000 agp. Hope it's not flaky when it arrives, installed and ran
ASRock 98
Win98SE Desktop
ASRock
Intel Core 2 Duo E8400 3.0GHz
1 x 512MB 667 MHz DDR2
Soundblaster SB0100 + Altec Lansing ADA885
ATi Radeon X800XT 256MB GDDR3
1 x SATA 120GB HDD
1 x SATA DVD-RW
Reply 44289 of 58450, by Tetrium
holdencars11 wrote on 2022-05-01, 07:31:
$2 SideWinder
Unsure if i should remove the sticker of leave it on for the reminder of the bargain hahh
That's a good bargain, especially if you bought it locally 🙂 so didn't need to pay for shipping as to Australia this would make it prohibitively more expensive.
Concerning the sticker, I think this is really just up to you.
The box looks to be in a fine condition. Personally I tend to just leave the stickers on as it's also a reminder of how good a deal something used to be back then like vanilla TNT2 or GF2 non-ultra cards for like €1 each as these cards typically have never been binned by the dozen.
There should be ample tutorial on sticker removal available. It's almost a whole science in itself 😜
I don't ever see joysticks for sale in thrift stores here in The Netherlands anymore btw. Or at least not where I live. Pickings are rather poor here these days.
My retro rigs (old topic)
Report spammers here!
Reply 44290 of 58450, by Tetrium
RaiderOfLostVoodoo wrote on 2022-05-02, 07:53:
I bought one at some point for €5 or so? It was still in the original tin.
Yes, the sticky keys were annoying, it's what ended up ending my Boomslang in the end. But they were far from shitty. You're forgetting what context these were in. This Boomslang replaced my cheap OEM PS/2 mouse and compared to this standard mouse the Boomslang was a god damn tiger!!
The keys breaking after a certain while was so common that entire websites seemed to be dedicated to bending the mouse buttons back.
So no, they were definitely not shitty. On the contrary actually, they were a huge leap forward compared to what we were playing with back in the day.
And you probably also didn't find them shitty or you wouldn't have bought 3 of them in consecutive order right? 😋
Yes, this is annoying, but it's also a thing of all ages. Ebay (or should I say the people advertising on there) was like this 10 to 15 years ago, like for instance people advertising the TNT2 M64 as a 64 megabyte graphics card etc just go increase their chances of someone buying it. Anything with a popular name is more expensive (often completely disregarding any logic to how much faster or better the item really is) and the same goes for things like "ultra".
Or even some brands will be more expensive, like stuff made by ASUS.
And kinda on the same note anything low-end would be considered junk by many end users. Even here on Vogons there would be some poeple who'd consider cards like Geforce MX (any) to be junk, "Oh a geforce MX? I threw all mine in the garbage and you should too because it is worthless and will never be good" but this also means these cards could be gotten very cheaply 😜
Reply 44291 of 58450, by imi
or my favorite: "perfect companion for a 3Dfx voodoo"
Reply 44292 of 58450, by Cuttoon
And I probably had a gaming mouse before anyone else here: Razer Boomslang But they were shitty. The left mouse button (or right […]
The Boomslang: I was aware of that thing - the silly name alone put me off.
- I need this PC for, like, some kind of studying stuff. Not a gaming PC!
- TF would I get a ball mouse?!?
- Fugly.
- I broke the button on a "mouse" before it was cool!
(and then proceeded to solder the middle microswitch to the left so we could go on playing maniac mansion.)
"Like 3dfx" - well, sure, what else would you write there? That's how I got the ad, although I'm only mildly interested in either.
Usually I'd remind you of Hanlon's Razor, that many sellers are just too stupid to know the distinction and there are several muggley ways in which a TNT2 is tantamount to a V3.
But, not this bugger. Going by his past sales, he knows his shit and puts that buzzword on every second of them - under various pretexts.
(I know I shouldn't just assume they're a "he" but hell, who are we kidding?)
Well, Ebay? I could live with any amount of SEO here if they just would weed out the outright false ads.
I've done it myself in a milder way: Sold a "Roland compatible" 8 bit MPU-401 card once. Made sure to put Roland in the title. Boy, did that work. 😜
Elite stuff of bygone age: It's not just our stuipid fetish for the cutting edge.
It's also the simple fact that back then, there was the same fetish for contemporary gear, but few could afford that.
So, these things, whatever their distinction to the rank and file - you'll basically have to square that offset today.
IIRC, I fried my Athlon TB 1400 back in the "paperweight" phase, shame...
I like jumpers.
Reply 44293 of 58450, by Shagittarius
Boomslang Bitch! Was a meme before memes existed. I can't find any evidence of it at this point but there use to be animated gifs and everything.
Reply 44294 of 58450, by Gmlb256
Tetrium wrote on 2022-05-02, 10:24:
Only serious gamers would diss low-end video cards. They were originally aimed as drop-in replacement for integrated graphics and often had better multimedia features than their high-end counterparts. However, they (but isn't always the case) are very useful for playing games from previous generations with much less struggle.
imi wrote on 2022-05-02, 11:30:
Years ago on eBay I saw one seller putting "3Dfx rival" or something like that on several Matrox Mystique PCI cards.
BTW, some video cards are indeed ideal for pairing it with early 3Dfx Voodoo cards (such as S3, Matrox, Tseng and nVidia up to GeForce4, the latter largely for Glide support though).
Reply 44295 of 58450, by Cuttoon
Gmlb256 wrote on 2022-05-02, 14:33:
You mean something like this?
https://www.ebay.de/itm/Coolermaster-GeForce- … r-/294899691098
("Gegner" being German for "rival")
Combining these two cards in the same sale is utterly idiotic, though.
I like jumpers.
Reply 44296 of 58450, by Gmlb256
Cuttoon wrote on 2022-05-02, 15:47:
You mean something like this? https://www.ebay.de/itm/Coolermaster-GeForce- … r-/294899691098 ("Gegner" being German for "rival […]
Yes, like that and it is ridiculous. It is advertising indirectly the other brand.
Reply 44297 of 58450, by Cuttoon
Gmlb256 wrote on 2022-05-02, 15:57:
Oh, appealing to collector's instincts to set up some diorama of "epic battle of the year 2000 3D accelerators" in their basement is nothing.
I'm still waiting for offers like
- "Ati Mach 64 ISA - completely unrelated to 3dfx cards."
- "badly designed motherboard, will not take those long 3dfx cards due to socket position, but otherwise, it's really great"
or certain classifieds shouting
- "You could spend a lot of money on a 3dfx card, but instead, how about some number one poontang?"
I like jumpers.
Reply 44298 of 58450, by chrismes
I searched my local offers for cases I liked and stumbled over an acrylic case that looked okay. The guy wanted 50€ for it and also had a few other parts he wanted gone (for free).
So today I went to pick the stuff up and went home with an Asus P2B-DS, two Pentium III 550, a Gainward GeForce 3 and another dual Slot 1 Mainboard from HP. The guy told me they still worked when he put them away, but we'll see.
There's another intense cleaning session ahead.
Reply 44299 of 58450, by Cuttoon
chrismes wrote on 2022-05-02, 16:26:
Now, is that "bought" or "bought combined with dumpster find" or do we need a third thread?!?
That GF3 looks awesome. I would like to buy a custom ATX Snow White coffin, as well!
I like jumpers.
