First post, by rootinit
Just in case anyone has ever experienced this, I wanted to reach out and check here. I bought a 1999 IBM Personal Computer 300GL (Type 6275-90U). It's a Slot 1 Pentium III, Intel 440BX chipset, with a riser board for adding PCI and ISA cards and 3 PC100 DIMM memory sockets.
About 50% of the time, when I try to boot, it immediately gives either a 1-3-1 or 1-3-4 POST error beep codes, which are RAM-related as per the user manual. If I turn it off, then wait a few moments, I can usually get it to POST and boot just fine. However, sometimes, it will still tell me a lower capacity number when looking at installed RAM in the CMOS settings.
Here's what I've done to troubleshoot:
  1. Used only a single stick
  2. Swapped the stick into each DIMM slot
  3. Swapped with a known working stick and did the same
  4. Reseated the CPU
  5. Swapped the entire CPU with a known working one
  6. Reseated the power connector on the riser board
  7. Swapped the entire PSU with a known working one
  8. Reset CMOS settings to default
  9. Upgraded BIOS to what I believe was the last version
It's beginning to feel more like a motherboard issue. Since it's difficult to source a replacement (IBM FRU 61H2347), I'm guessing that I may have no real recourse to repair this machine. Any thoughts on this?
IBM ThinkPad 755Cs (Win 3.11) • IBM ThinkPad 365x (Win 98SE) • IBM ThinkPad TransNote (Win 2k)
IBM PC (PC DOS 3.30) • IBM PS/2 Model 80 (Win 3.11) • IBM PC 300GL (Win 98SE)
AT&T PC 6300 (MS-DOS 6.22) • Dell XPS T550 (Win 98SE)
Reply 1 of 11, by Strahssis
You could try cleaning the RAM sockets with some isopropyl or ketonatus alcohol and a soft tooth brush. Also check for any damaged pins in the RAM sockets, although I don't expect this to be the issue, since the system sometimes does work.
Since it doesn't work on the first attempt, but it does work on the second attempt, it kind of sounds like a capacitor problem. I'd try looking at the motherboard and see if you see any bulging or leaking capacitors. If it is SMD capacitors, look if there is junk underneath them.
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Sound Blaster CT2800, 32MB RAM
Satellite 220CS: Pentium 133, SVGA DSTN, Sound Blaster Pro, 64MB RAM
Contura 420CX: 486DX4 75, VGA TFT, Roland Serial MIDI, 16MB RAM
Reply 2 of 11, by paradigital
My guess would also be capacitor and voltage related. Seems that warming components up causes more stability, which is a common failure mode of bad caps.
Reply 3 of 11, by Horun
Agree is points to caps. Also besides the temperature thing the caps could be electrically leaking so after the first or second power on it sort of heals them so they function close to expected instead of not filtering/semi shorting/etc when first powered on.
Reply 4 of 11, by rootinit
I should note that even after being on for a long period of time, it doesn't boot reliably or anything. I wish I could tell if there was a bad cap somewhere, but visual inspection of the board is clean. I don't know where I'd start. I also noticed that it has a way higher chance of not booting when all three slots are populated.
Reply 5 of 11, by rootinit
Strahssis wrote on 2022-05-10, 20:31:
Just tried cleaning the slots with compressed air and isopropyl alcohol, but no dice. I don't see any damaged pins in the sockets either. It is happening with all three sockets, so I'm guessing it's not an actual slot issue at this point.
Reply 6 of 11, by Horun
Did you clean the DIMM's edge connector ? Use paper towel with ISO alc....and do not be afraid to scrub hard ;p
Reply 7 of 11, by rootinit
Horun wrote on 2022-05-10, 23:57:
I did actually. Thanks for your suggestions though.
Reply 8 of 11, by rootinit
I took a closer look with better lighting after removing some components. Y'all were right on about this being the issue. I found some of these "Chhsi" branded caps that were part of the known bad caps from that era. I am a bad solderer, but will try to get these replaced, and report back.
Reply 9 of 11, by darry
rootinit wrote on 2022-05-11, 01:37:
Just as a side note, Chhsi's web site did not change much between 2001 and 2004 (their corporate blurb mostly says they started in 1977, but at least one place mentions 1997, which I presume is possibly a typo) , but their contact info went from featuring an @chhsi.com.tw address to featuring an @yahoo.com.tw one . Infer what you will from that . 😉
https://web.archive.org/web/20001019005401/ht … w.chhsi.com.tw/
https://web.archive.org/web/20040727051541/ht … w.chhsi.com.tw/
Anyway, specs are here for their various capacitors series, if you need them :
https://web.archive.org/web/20010215170329/ht … ducts/index.htm
https://web.archive.org/web/20040806160321/ht … ducts/index.htm
EDIT : The WG series series were apparently arguably their "top of the line", which isn't saying much... Did WG stand for "Wasteful Garbage" ?
Reply 10 of 11, by rootinit
darry wrote on 2022-05-11, 03:39:
Just as a side note, Chhsi's web site did not change much between 2001 and 2004 (their corporate blurb mostly says they started […]
Interesting stuff. Thank you. I've been poking around a bit more online, and see that these particular ones were failing as early as 2006. The other side of the caps had some specs for me to use, so I ended-up buying these Panasonics as replacements. I'm glad that all the other caps IBM used seem to be Rubycon and Nichicons.
Reply 11 of 11, by rootinit
Problem appears to be solved! New Panasonic caps are swapped-in, and I ran a few rounds of Memtest86 perfectly.
