First post, by WJG6260
Hello everyone,
As the title says, I’ve been wondering if the quirky Intel VC820 motherboard supports Tualatins. I recently purchased one of these boards with the hopes of testing an alternative to a 440BX system I’ve got. I am in a weird way interested in RAMBUS setups and wouldn’t mind giving this a go, since i820 supports native 133MHz FSB, 4X AGP, and 1GB of RAM—theoretically putting it ahead of i815 in my book, due to that chipset’s unfortunate 512MB hard limitation on RAM.
As much as I love the 440BX chipset and my ASUS CUBX-E, I’ve had stability troubles at 133MHz with a Tualatin. I suspect it’s due to the overclocked AGP bus, but I disabled Side Band Addressing and found some success in stabilizing things there. Performance is great, but I have some occasional hangs on shutdown and after closing games and find this to be annoying.
I found an old thread on HardForum from 2004 where a user claimed to have gotten a Tualatin working on an Intel D820LP board (or perhaps a VC820; it is unclear as I’m not certain which board would have been in his Dell XPS but it would’ve absolutely been one or the other).
I have a pin-modded 1.26GHz Tualatin from the Korean eBay seller who pre-modifies them and it’s great. Their site claims support for the VC820 through a BIOS update. Would anyone happen to either have that update or know something about this? I attempted to contact the seller and didn’t hear anything back.
I can’t find anything definitive saying this board doesn’t work, but then again, I can’t find anything saying it does either.
Anyway, thank you in advance for your thoughts and help!
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
Reply 2 of 32, by Tetrium
Intel boards of that era tended to make use of BIOSes that effectively locked out processors they deemed unwanted to upgrade to (my guess would be they wanted you to instead of upgrade, buy a new board (with Intel chipset of course) but could be a number of reasons not mutually exclusive).
In some cases using an older BIOS could net one with better compatibility as newer BIOSes tended to lock out newer chips more often.
So for Tualatin I'd guess you'd need either an older official BIOS, or a modified one.
I have a single ordinary VC820 somewhere, but only used a Coppermine with it.
Another reason it perhaps could be not-working is the slotket perhaps? VC820 is a Slot 1 board, dunno from top of my head whether or not the other one is Slot 1 or s370 but a Slotket could be additive to getting another potential problem.
My retro rigs (old topic)
Report spammers here!
Reply 3 of 32, by flupke11
I've just set up the 820 on the bench board. The mainboard is brand new, it still has that typical PCB-smell when you get it out of the antistatic sleeve. I wonder if they put that smell in cans, just like they do with new car smell or wet dog smell.
Boot version is VC82010A.86A.0031.P11, out-of-the-box. Be warned that the large capacitors are very close to the slot-1, some of my Slot-1 CPU's have custom coolers, and the backplate of these coolers protrude by about a centimeter which renders these unusable on this board. The OT's goal is using a pinmodded Tualatin, which means a Slot1-FCPGA convertor. That shouldn't be an issue.
Testing:
1 64 MB stick PC800 + continuity rimm: OK
1 256 MB PC1066: OK
2 256 MB PC1066: OK
It boots happily with a Katmai 500, no surprises there. Speedsys (569,3)
No issues with a 700/256/100 Slot 1 Coppermine. Speedtest (795,55) - 743,70 MB/s - The P3B-F got 804,99 in Speedsys with this CPU, The 100 FSB is a bit more agressively timed than Intel's stock choice (99.73).
Soltek SL-02A++ Slocket with a Celeron 800/128/100: No issues, works as advertised. Speedsys (909,82) - 743,69 MB/s
Soltek SL-02A++ Slocket with a PIII 866/256/133 SL4CB: no issues. Speedsys (985,03) - 984,60 MB/s
Soltek SL-02A++ Slocket with a PIII 1000/256/133 SL5FQ (Tualatin-a-like, 1,75V): doesn't boot
Soltek SL-02A++ Slocket with a PIII-S 1400/512/133 SL6BY (Tualatin, 1,45V): doesn't boot
Powerleap iP3/T with a PIII-S 1400/512/133 SL5XL (Tualatin, 1,45V): doesn't boot
Powerleap iP3/T with a PIII-S 1,26/256/133 SL5XL (Tualatin, 1,45V): doesn't boot
tl;dr Anything newer than stock Intel Coppermines won't work on my board Tualatins don't work (at the current state of affairs)
    196.46 KiB
    45.68 KiB
Reply 4 of 32, by mastergamma12
Looks like you'll have to track down a P3C-E if you want an 820 with Tualatin.
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 6 of 32, by mastergamma12
flupke11 wrote on 2022-05-16, 21:22:
We haven't tried other BIOS's but Intel being Intel, I suppose chances are very slim indeed that it'll work with an unmodded BIOS.
I had a D815EEA2 a few years back, Had to use an older bios or it would display a shutdown in 10 sec message whenever a Tualatin was inserted, ended up dumping the board as it kept killing SD Ram sticks.
Reply 7 of 32, by flupke11
Perhaps to soothe the OP's disappointment, my Aopen AX6C (an i820 board with the original 3 ram slots) also doesn't like Tualatins. That's more due to a voltage issue, because the Powerleap iP3/T does function on that board.
Reply 8 of 32, by WJG6260
Sorry about the delay in replying to all those who have responded but thank you for your invaluable insight and efforts! flupke11, I really appreciate you taking the time to test your own board. I'm a bit bummed that it didn't work, but glad to now have an answer.
I actually just received my VC820 in the mail today and broke it out. It's a really nice board and super well-built. With later BIOSes it boots strikingly quick.
Interestingly, my "PIII 1000/256/133 SL5FQ (Tualatin-a-like, 1,75V)" booted with BIOSes P17 and P18 just fine. I tried the pin-modded Tualatin and neither my ABIT slotket that goes to 1.3V nor my generic "Super Slotket III" worked at all, with the BIOS stopping at POST code F5. Weirdly the thing just wouldn't even boot with the ABIT slotket. I wonder if it's related to the slotket's onboard voltage clamp? I only have two slotkets that take FC-PGA chips, so I'm not sure what to think.
I think mastergamma12 is right: a P3C is pretty much the way to go if you want i820 and a Tualatin. The KC19+ I have does actually boot just fine with the original FIC BIOS with a Tualatin, but it just won't POST with any hard drives larger than 32GB and it has proprietary fan headers. Plus the PC87200VUL ISA bridge lacks DMA support (God knows why...).
I think Tetrium and mastergamma12 are both right about BIOS limitations here for sure. I wonder if there's anything that can be done about this? The Korean eBay seller who provides these pin-modded Tualatins says that the VC820 is compatible, and a BIOS update is free; I wonder if this BIOS update exists because the seller just hasn't responded at all.
I may just stick with the 1GHz Coppermine if I have to, as it should be plenty quick for my purposes. I'd hoped to use the Tualatin, but it's alright if I can't.
Thanks again to all those who've helped out and contributed their thoughts!
Reply 9 of 32, by Tetrium
WJG6260 wrote on 2022-05-18, 19:18:
Sorry about the delay in replying to all those who have responded but thank you for your invaluable insight and efforts! flupke1 […]
Hypothetically speaking, definitely possible.
The problem is intentionally put into these bios files, so it's a software problem at this point.
Ftr, I don't actually know if such a bios file already exists. I wouldn't be too surprised if it did but finding it may be the tricky part?
I don't have any experience modding bios files though. Some bios files are probably easier to edit than others.
Would be great if someone with more experience on this subject would reply here. But I don't see how this is impossible unless the actual tools to succesfully mod these bios files simply don't exist (or perhaps you'd need to go experiment with a hex editor or something but I really cannot recommend it unless you already have plenty experience using hex editors and you know what you are doing and have lots of time).
I ran my VC820 with (iirc) a Coppermine 933MHz just fine 🙂
Tbf the difference between a Coppermine 1000 and a Tualatin 1400 is less noticeable mostly because (due to how fast hardware and software evolved at the time) I reckon there won't be many games that will run on Tualatin and not on Coppermine 1000.
Reply 10 of 32, by flupke11
Thbks @WJG6260 for your reply. In the mean time, I've upgraded the P11 to P18 BIOS and it does boot with the SL5FQ. So between P11 and P18, they've inserted the CPU microcode of that Coppermine revision.
Same issue with my Slot 1-Tualatins (Upgradeware Slot-T, LinLin on Soltek and Powerleap iP3/T): second led on the diagnostic panel ("Processor, cache, etc.") is lit. So Tetrium is probably right, the issue is not electrical like on my older AX6C, but rather a softwarebased lock in the BIOS. Alas, also my knowledge is non-existent on BIOS-modding (or I would have enabled 150 and 166 MHz on my P6S5AT)...
Reply 11 of 32, by Tetrium
flupke11 wrote on 2022-05-18, 20:25:
What was the problem with your AX6C?
Btw, I'm not absolutely sure it cannot be an electrical problem with the VC820. For all we know, both problems exist but we aren't even making it past the 1st of 2 roadblocks 😜
Reply 12 of 32, by flupke11
Tetrium wrote on 2022-05-18, 20:57:
There's not really an issue with the AX6C, other than I should not use 3 sticks on it (there's a reason why all newer i820 moved to two ram slots). The Powerleap iP3/T works on it (which is a plus, compared to the VC820), but not the other Tualatin conversion solutions, which brings me to a (perhaps premature) conclusion it's an electrical issue as in the VRM not providing 1,5V.
Reply 13 of 32, by TgumanoidT
Here a man from Korea sells a modified Celeron Tualatin. https://www.ebay.com/itm/281931957654?hash=it … 8gAAOSwqhFgXwQ0
Supported motherboards include Intel VC820, But there is a note: New bios is FREE!!
I tried to write to the seller about the modified BIOS, but there was no answer.
Reply 14 of 32, by WJG6260
Now this is a plot-twist! I haven’t given up, and it seems that someone has indeed got this board going with a Tualatin!
As to how, well, I’m not sure. I’ve messaged them and will keep all those interested informed as to my findings. Interestingly, their COU-Z readout denotes the bios as version “.P18.” Perhaps this is a modified version?
Reply 15 of 32, by kitten.may.cry
TgumanoidT wrote on 2022-05-29, 21:16:
What the heck is this CPU, dood???
It's not even listed in cpuworld DB.
Reply 16 of 32, by WJG6260
kitten.may.cry wrote on 2022-06-06, 20:00:
Looks like the picture was modified to have an S-Spec of SL6XX, where the XX is C6 or 4V, whatever version the seller is going to send.
I can vouch that this seller is legit; his pin-modded 1.26GHz PIII-S is awesome.
Reply 17 of 32, by flupke11
WJG6260 wrote on 2022-06-06, 19:53:
Bizarre, but interesting indeed. In my experience, the stock P18 did not solve the issue. I'm eyeing this thread!
Reply 18 of 32, by WJG6260
Same here! I was tinkering with P18 earlier and no dice. I’ll keep you posted on a response, if I get one.
It seems this is possible but I just don’t quite get how! I did some reading, and it seems Intel AMI BIOSes aren’t generally modifiable. This is peculiar indeed…
Reply 19 of 32, by WJG6260
Something odd is going on here. On second look, it appears as if CPU-Z displays some weird information. Why is AGP 3.0 listed as the specification, when this is an AGP 2.0 board? Is it simple mis-detection, or is there more at play here?
Considering the weird bios version listed as just ".P18." and the odd Windows XP System Properties readout (beyond the customization, why does it say "1400MHz 1.4GHz" when XP usually says something like 1.4GHz 1.39GHz (just an example, but this is what I'd imagine in this case). Also, I've never seen "Intel(R) Pentium III(R) CPU family," as the system string, but instead something like "Intel Pentium III processor."
Any thoughts? I'm curious as to what everyone believes. Is this real, or is something potentially screwy going on?
