I never had stability problems or some compatibility issues on NF2, did use EPoX 8RDA3+, ABIT NF7-S V2, ASUS A7N8X-E.Used these boards for my main system, first the asus, then the EpoX, and since i found the ABIT i use that mobo, it works great, never had any problems, and the system is heavy OC as well on the CPU side. For VIA boards i have the AOpen DX34R-U that i did heavy use compared to others VIA boards, never had problems with that board too. But reading back in a local forums, back in 2003-2004 when socket 462 was new, imagine everyone did state how shitty the VIA based boards are, how unstable, they are, no AGP/ PCI lock under the KT880, and more and more.. KT880 is the last VIA chipset, and is newer then the NF2, yet it also does not support 2GB above DDR400 speeds, so i dont find it to be of any use then, and to prefer it over the NF2. So in that forum they did state that, in 2003/4 everyone was with NF2 imagine, since anyone that did dare to sacrifice money and time on a VIA board, was disgusted, how shitty that chipsets was, no matter KT400 or KT600 we talk...
Maybe u got a bunch of garbage ASUS NF2 boards, and this is why u think the chipset is bad, as ASUS boards are the worst garbage out there, they like to die without any reason too, happened to me couple of times...
Wrong about the ABIT, when they did become oranage in PCB color, they are high quality AF VERY high... The whole damen board is covered by expensive high end Japan caps Rubycon, it is stable AF...
I am using this board since many years found it in 2012, it is rock solid, with modded bios holding 2600+ Mobile Barton up to 2.6GHz real speed, never had any problems, i did even use it for daily driver back in 2017 for 2 months the system is very stable believe me... I power it up from time to time to play GTA VC, Devil may Cry 3, GTA SA, NFS MW, or brouse the web a little, since it is weak for that kind of crap, and i dont spare time to optimise with better browser..
https://imgur.com/a/mubGE
DFI was alot worse in build quality, but yes older ABIT boards the yellow ones, before the great orange ABIT NF7 V2, was unstable mostly, cuz of shitty capacitors... EpoX similar thing, but once they are recapped, they was also rock solid... I hade one or 2 EpoX 8RDA boards, that did came with 9 of the most important caps, near the VRM and they was high quality SaNyo caps, and the build quality was alot better seems then on most EpoX boards, not sure wtf was that...
Ok tell me then if you consider the state of art ABIT NF7 V2 (the orange one) to be bad, then what socket 462 do u see as high build quality then >? I can think of couple brands, BUT depends on what caps they did use. AOpen have some times whole boards covered in Rubycon caps, GIGAbyte boards have also mostly Japan caps, and MSI as well, but there depend, some of them have good caps like Panasonic, others have shitty KZG caps, that like to blow up as usual...
These 2 MSI boards are interesting, the red one is lower class mobo, yet it have mostly Rubycon caps, while the black Platinum high end have garbage KZG caps, that did blow up...
Meanwhile look at the ABIT, it is state of art, the build quality is very good... The whole board is covered with Rubycon caps, and they are expensive you know, even the smaller one...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
