First post, by buckeye
Just installed this board on a new winXP build and noticed high idle temps for ICH/MCH. Once start playing games and etc. they get into
the eighties easy. ICH is the hottest as the geforce 280 is right over it so can't stick a fan on it. Is this normal behavior on these parts of
the mobo?
The only solution I can think of is replacing the video card with a shorter one allowing ICH to get more air. Is it feasible to replace the
thermal paste on the ICH/MCH? Never looked into it. Granted this board isn't "high end" so the general layout could be at fault.
    1.85 MiB
Reply 2 of 9, by SPBHM
not the same board but my DG965WH has a very warm ICH, I don't know if it's normal or it's degraded with lots of leakage, overvolted or something, but it has a heatsink, and without direct airflow it goes over 80 c easily, I placed a 80mm basically on top of it and it can run around 60 like that, but it still feels pretty hot for what is supposed to be a 4W TDP chip with a heatsink on top of it and huge amounts of airflow
I guess, that's the benefit of most of my lga 775 boards not reporting ICH temp and they all run hot, I don't know.
Reply 3 of 9, by buckeye
SPBHM wrote on 2022-09-21, 18:05:
Don't have the option of adding a fan to the side panel since it's glass but I can add one to the front. I'm gonna pick a good one too
like a BeQuiet or Noctua brand.
Reply 4 of 9, by Horun
What are you using to check those temperatures ? Have seen many OS based apps not report some Temps correctly (some allow an adjustment for chipset type instead of just "reading it") ... just a thought
Reply 5 of 9, by rasz_pl
buckeye wrote on 2022-09-21, 21:04:
you can even bodge old power supply fan wired for 5V inside the case somewhere close to chipsets
Reply 6 of 9, by buckeye
Horun wrote on 2022-09-22, 03:42:
SpeedFan and the Intel utility that came with the mobo. Heck, I even went into the bios and watched the ICH temps climb from 57 to 73 within 10 minutes.
Reply 8 of 9, by Roman555
Intel DP35DP has a good big heatsinks on a chipset. It would be better only if heatsinks are copper pipes like overclocker's mainboards have.
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 9 of 9, by buckeye
Roman555 wrote on 2022-09-22, 20:06:
Yeah I've been shopping around ebay for those, they come with a "nominal" fee unfortunately even used.
